septic field frozen
/ septic field frozen #61
I agree with EGON, that feed line MUST to be dry between pumping operations, in other words it must NOT be level but needs a decent slope to drain out from either end. (preferably to the field.)
And from any field that I have ever been involved with the field MUST be perfectly level (no slope) as otherwise all effluent will rush to the low end and promptly saturate that field end.
Yours is 4:1 slope??? something wrong there.
A field is meant to EVENLY be fed so that absorption is slow even and gradual.
Big unanswered question still remains:
How long is that line from pump to the field? and is that rigid or flexible? What size? That line wants to drain perfectly dry after each pump cycle.
All appearances are that the feed line is darn close to the surface and therefor extremely suspect to freezing, especially since your field is 'above ground'.
/ septic field frozen #62
From your pics I get the impression that your 'above ground field' is a fair distance from the house/tank.
And to feed the field the feed line is for sure barely below the surface.
/ septic field frozen #63
With a sand mound if you have freezing problems it can only be in the indexer ( not well insulated) that switches the affluent from one run to the next or the pipe going to the field is not on and up hill slope so it can drain back into the pump chamber. I order for it to drain back into the chamber the installer drills a 3/16" hole it the riser from the tank so that when the pump quits the line can drain back.
/ septic field frozen #64
Sure sounds like a freezing issue to me. You will need to find out where exactly to remedy the problem.
On a different note about good septic tank health; First, I am a Master Plumber and have been for over 25 years.
Lots of poop with little water is good. Poop from different people is a good thing. (different bacteria) so when friends come over, offer a drink and sweet roll and don't let em leave until they poop. A little plain yeast down the drain every month or so is a good thing. Do not use anti-bacterial anything to clean with. (that will end up down the drain) Last, and I'm serious, the best bacteria starter you can get is a dead cat in the solid's side of your septic tank. You simply cannot get better bacteria than a decomposing cat. Lastly, when/if you have the tank pumped out, fill it back up with water as soon as the pumper is gone if it's a single compartment tank. This prevents solid's from leaving the tank and plugging the distribution box.
There is another problem called "biomat". Usually this only forms on old poorly maintained systems. I doubt this is the case here.
The picture (avatar) was taken a week ago; the lid on my distribution box rotted away and caved in letting dirt in and backed up my whole system.
Yes the main feed line is dry between pumping operations as i have seen the pump drain back after it shuts off and i have verified there is no one way valve in the line. The slope of the mound is 4:1 it is the standard construction requirement based on the size of your mound.
I will try to find information on the main feedline depth and type of line.
/ septic field frozen #66
I think by 4:1 you may be referring to the slope of the perimeter of the mound the lines look level as they should be in your pic.
yes sorry for any confusion.
OK I got some additional information:
-4" ABS PVC from the house into the 2 stage septic tank (solid side/liquid side)
-submersible pump inside the liquid side that runs into the 1-1/4" poly pipe schedule 75 6' below ground
-the poly pipe (runs from the septic tank to the field) transitions into a brass fitting turns UP into the manifold and then distributes into 1-1/4 perforated PVC.
/ septic field frozen #69
From what you say my take is the problem lies in that 1 1/4" poly pipe especially with the upturn brass to the manifold.
There is no way for that line to empty itself dry for 2 reasons.
1st poly just can not be laid flat enough to drain
2nd the upturn brass end holds fluids back.
My take is you freeze the contents of the poly pipe run however 6 ft deep generally should be below frost* level.
While all being said effluent (contents of the poly) generally should not freeze unless the household uses way to much water.
*frost level can go deeper in a wind blown field as snow is actually a decent insulation.
One solution I can suggest is to excavate down to 6-12"(closer if you dare) above the poly line and cover with 2ft wide strips of high density foam insulation (centered on the poly pipe line) and re cover with fill.
The theory being that ground heat will be retained under the foam insulation which also will prevent deep frost penetration.
I have used this system for pumped pure lake water lines and that with even less ground cover. (like even 6-12")
One septic system I did (25 yrs now) has merely 12" of cover without any insulation however it self drains after each pump cycle. (make that 2 systems)
An alternate method ( but more difficult and costlier) would be a heated tracing wire adjacent to the poly line to keep it above freeze levels. Some modern tracer line is self regulating and economical to use but pricy at purchase.
For that matter you could for that usage simply buy roof gutter heated cable and lay it adjacent to the poly pipe and wrap it on the vertical riser section.
I would not believe any of the above solutions would need be mentioned to the authorities as in effect they do not technically modify the approved field plans.
I would think your installer could be coerced into assisting with the excavation in order to protect his reputation. Worth a try.
From the pics you posted an old fashioned snow fence or even a cedar hedge upwind of the field should create considerable snow drifts to generate a snow layer of insulation.
Not to contradict but i like a good conversation:
If the poly line was freezing why would the field freeze? In my opinion IF the poly line froze the field lines would be empty and there would be a blockage/ice in the poly line or middle of the system. The field would be able to discharge the effluent from the last cycle making the field lines open and not full of ice like I saw. (remember I have access ports into my field)
second:
when the field first froze and I turned the pump on manually and shut it off, effluent drained back into the tank from the poly line.
It is possible that the line does not fully drain back causing a blockage (ice) in the manifold or mid way in the line, but then again the effluent would then empty in the field and leave me open field lines with a blockage else where.
I do need some extra information:
earlier in my post I mentioned: "system was sized for 330 gallons per day with a .15 Efflucent soil loading rate"
I know for a fact that there is no way the two of us are using 330 gallons a day, we each have a quick 5-8 minute shower in the morning, leave for work come home at supper bathroom a few times. This is our daily routine with the addition of the dishwasher 3-4 days a week and laundry one a month. I know we put in more water than "bacteria/poop".
I feel our issue is not using enough water, not creating enough heat, and not enough coverage.
thoughts?
/ septic field frozen #71
OK, they actually installed the system so that the poly should self drain. That's good but unless there is a good slope back to the tank it will never empty dry.
Poly comes in coils and it is virtually impossible to lay it perfectly flat. With that 1 1/4" poly it only needs a 1 1/4" dip over the entire run to trap some water.
Poly is shipped in about 3' coils so one coil is +/- 10' long. I defy anyone to uncoil 10' and get a perfectly flat/straight length. Your pics suggested a very low slope between tank and field so I suspect the drain back angle to be slight and the slightest dip in the line would trap water.
All the theories being discussed, effluent generally does not freeze but pure water will.
Are you sure that there is not an excessive amount of pure water entering the field?
Like a leaking toilet float valve? Automatic ice maker?
(don't laugh, my daughter's tank froze up simply due to that. They pumped late fall so there was a lack of bacterial action to heat up the effluent and as a result system froze up. Oh and they had a leaking toilet valve thus mostly pure water in the tank)
LOL, shower less, poop more.
Septic systems are generally sized based on number of bedrooms and that can be a mistake as bigger then requires more bacterial action to be effective. Bacteria will be more active in a contained area and certainly diluted in a huge container.
Oldtimers always suggested dumping macerated pork liver to activate the bacteria in a tank.
I feel for you as I have lived with your type problems either personally or via clients dilemmas.
I do not have automatic ice maker, I do not think the toilet leaks as i do not hear it "re charge" unless the toilet is flushed.
Do you think/agree with my #70 post? or do you think i still have an issue in the mainline?
I think we can agree my main issue is not enough water usage in the house therefore not causing the pump to cycle enough and not enough poop.
/ septic field frozen #73
Sorry I had missed fact that you could inspect the field and confirmed it also frozen.
I do stick with the poly not being able to be laid out perfectly flat due to the nature of the product.
Going back to basics, effluent from a properly operating septic should never freeze.
My field is barely 12" deep but covered with snow and I also pump from the tank uphill 16ft to the field.
20 years operating with no problems. When I open the tank for service PHEW, man it is working. (by law we pump every 2 years) My tank and pumping station are under my driveway that is plowed all winter and Jan & Feb were always -20deg or colder this year.(even -10 every night last 2 weeks)
Back to basics. Sounds like maybe you don't have any bacteria in that tank that would create heat just by the nature of the beast.
Chop up some pork liver and get the bugs working.
Hey, never use Javex, Clorox or any toilet cleaning disinfectant products.* They all contain chlorine which kills all the bugs that promote good septic action.
Could that be your problem? Wife a 'clean freak'?
While I never tried it, they claim that you can kill a septic system with a gallon of Javex.
* that goes for the bricks that you hang in the bowl or tank as well.
/ septic field frozen #74
I'll agree with the latest theories. Can't suggest a solution other than having a group of politicians over.
/ septic field frozen #75
Limited amount of bleach will not harm your system but throwing old pills down the toilet will kill the enzymes
that break down the action. The only thing in the tank that breaks down the solids comes from your stomach
anything else is an old wives tail. As for why your field froze ?? I've heard of it before but never seen it happen. Washing clothes in cold water is also not recommended with a septic system. It may be possible that your pump is cycling to often for the size of the field. I've never heard of one set up to pump from a 2 compartment tank generally there's a 2 compartment tank then a 500 gal. pump chamber. Reason for the 500 gal. chamber is so you have a 3 day retention in case of a pump failure. The dosing 100 gal. or more is determined by the size of the fields hydraulic loading rate which in your case should be plenty large enough for 200 gal. doses.
/ septic field frozen #76
The surrounding land is getting saturated, freezind and creating a dam. Trapped water then feezes in the DF . I would trench and drain the surrounding land, if grade permits.. If not then build a "dry well" to recieve the excess water. The most common reason for this problem is an inadequate Perc rate in the field laterals (Soil not porous enough) or water table is too high under the field.
/ septic field frozen #78
Soft water requires salt..salt is antibacteeriologic, ergo if you run a salt-type water softener backwash into your septic tank, you kill the heat producing bacteria. (and get your DF laterals plugged.) Salt backwash must NOT go into the septic system! Dig a 4'x6' drywell for that purpose. Line it with field stones. Pump the bacKwash there. Bingo, bob's your uncle. :thumbsup:
/ septic field frozen #79
According to the literature I have the only reasons for freezing they state is foot or other traffic over field or improper installation. The dose rate may be far less than I stated the HLR should be in the neighbor hood of .45 to .65 gal. per sq. ft. per day. So the size of the field is the determining factor.
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
New 1.5x27 Ratchet Strap (A65583)
New 1.5x27 Ratchet...
2021 Ram ProMaster 3500 Box Truck, VIN # 3C7WRVLGXME588513 (A65563)
2021 Ram ProMaster...
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
Crane (A64194)
Crane (A64194)
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
