septic field frozen
/ septic field frozen #21
I'd wonder too how 4' of cover would protect from 6' of frost. Even with hay bales over it. If I had 6' frost lines I'd want 8' of cover just to be safe. Nothing, and I mean nothing, is more aggravating than sewage problems in winter. Hope you find a solution.
/ septic field frozen #22
In normal soil, frost has to overcome the typical ground temperature as it works downward. You don't have that reservoir of ground temperature in the mound really, at least not the same as native settled soil. So I bet the mount has a significantly less frost resistance than the ground. If you have a 6' frost line in regular soil, I don't see how a 4' mound of sand/stone has a chance, even with bales of hay on top. Maybe there is a better way to insulate the mound from air temperature above so that it can trap/hold some ground temperature, but I have my doubts.
I too was wondering that. Mine has been working flawlessly for the 21 years I have been here. No pump, the 'stuff' just runs out into the tank and then to the drain field. I get my tank pumped every two years. In fact this year is THE year to get it pumped.
Where I grew up/older the septic system was in the ground and that got pumped once in 17 years.
/ septic field frozen #23
I have a pump style installation as house being near waterfront leaves no choice but to pump uphill to the drainage field.
We actually pump about a 16ft rise.
Naturally a check valve is needed otherwise the backflow could actually un screw the pump impeller blade.
We actually drill a 1/4" hole in the flap of the valve to create a slow release or emptying of the line which in turn prevents freezing as due to terrain is a mere 10-12" deep.
The drainage field is conventional with a mere 12" of topsoil coverage.
That installation has operated faithfully for over 20 years except for one pump failure.
Do you think if i excavate the mound and install rigid insulation above my lines and 4' away in either direction it will help or hurt me? What about running the heat tape in the lines like i suggested?
/ septic field frozen #25
Hah, had one system (conventional) that got its first pumping at 22 years of usage.
The tanker guy claimed that it looked like a normal 2-3 year since last pumping.
The big joke is that it was hand dug, hand poured and mixed concrete on site with hemlock planks as the cover.
Nowdays by city ordnance it must be pumped every 2 years or a fine gets levied.
/ septic field frozen #26
Just a thought on your septic mound system.
I had a new one installed which failed completely inside of six months. It was replaced by the contractor at his cost, and what I initially wanted, a lagoon system, was installed. The new system has operated problem free for eight years now.
I think your problem might be that water or liquid waste remains in the pump discharge line and gets frozen. I know on my mound system, that the pump discharge pipes had drain holes in front of the pump outlet to allow the discharge pipe to drain after the pump shut off.
The failure of mu mount system was due to the completely inadequate construction - from risers leaking ground water into the holding tank, incorrect construction of the mound piping etc. The diffuser pipes are supposed to have sprayer guards to prevent water cutting holes through the sand beds causing preferential water pathways.
I am probably not very clear on what I had, but I think you might need to look into the pump discharge pipes freeing from static water in them. The water needs to drain back into the pump chamber after the pumps has stopped, to drain the lines (should be a positive slope upwards to allow water to drain back and out of the pipework).
My system was a total cock up from day one - I hope yours is better constructed.
PM me if you want further info. I have five or six local newspaper stories that I would be willing to share of you are interested.
/ septic field frozen #27
Honestly I suspect you want to analyze your usage habits or routines.
In all probability your installer has a certification of some kind otherwise the city would not have issued a permit.
Before you go wild with theories and solutions have a serous talk with him as for sure he wants to protect his reputation.
While retired now, I have been to go to guy for 75 property owners all which are on septic systems.
In our earlier days we were fortunate enough to have had many government experts provide us with valuable advice for us pioneering builders.
The speakers were the main attraction of our AGM's, that as well as a wine and cheese event.
As indicated I have seen all kinds and styles of septic solutions and quite honestly some newer ones simply amaze me.
I am starting to suspect we are seeing a "better mouse trap syndrome". Next will be a computer controlled field. (One approved system actually includes circulation pumps and individual monitors for each field pipe run)
10 years ago a good installation was in the $3K range but today expect to spend upwards of $10K (know of one that hit $18K)
/ septic field frozen #28
Piloon,
Your septic work is cheap compared to what they now charge in BC. My non operable system cost me close to $25,000 - which is a lot of money to a pensioner like myself. Needless to say, I went to court and won over the heap of sh*t I had :cool2:
I think the OP needs to get the regulating body involved as he should not have problems with a new system. My advice would be to start with questioning construction and design.
/ septic field frozen #29
What's a RM If them and the contractor say that it's a good system they may both be full of it. Just wanted to check in because we've lived in the country 40 years our friends and relatives live in the country never had to replace an old system. Our present house system is 70 years old --- Trevor
/ septic field frozen #30
I think RM is the Regional Municipality or local Health Department.
A new properly designed system should not freeze in use. Something is very wrong both in the design and the construction.
/ septic field frozen #31
Well were supposed to easily have 4 ft frost depths around here that's why building footings by code are 60". Under the plowed roads its been said the frost has run a full 6 foot deep this year caused a lot of water main breaks because that's deeper than the average pipe installations
My system has less than 24" of ground cover plus only snow cover hasn't ever been frozen as far as I know
Granted it not as cold here as the OP has stated his conditions are but there was very few days above freezing and temps were steadily at zero or below for extended periods again this winter.
Now at least three times here the draining of the delivery lines has been mentioned as a possible cause. My system has the same drain hole in the pump line connection but it does only drain back the delivery lines the actual bed pipes are level and were set with no pitch back so whatever fluid is in the pipe has to drain on it own. My drain bed does sit at least 4 feet higher than my the top of my tank and the pump sits another 5 ft down inside the tank. So I have a good 9 ft of delivery head at least maybe over that and I seen much more
If I read his description correct the drain pipe is only 1 1/4" dia. with 1/8" weep holes. After pressure feed and drain back how efficiently that would continue to drain the effluent left in the pipes is questionable at best. If I remember right I had to drill my 3/8" drain holes one every foot over the 40 ft lateral.
Installing rigid foam insulation could only help against freezing but also increasing the drainage time of the laterals with some larger hole might help too :confused3:
/ septic field frozen #32
I don't think you appreciate how cold it gets in Manitoba in the winter.. It's -20C or worse every night for 2 months at least. And then in March it flips almost overnight to +30C.
My system has the same drain hole in the pump line connection but it will only drain back the delivery lines, the actual field pipes are sloped back towards the end of the field where in theory whatever fluid is in the pipe has to drain on it own, IF it takes to long it freezes or if the ground around my field is frozen the lines stay full as there is nowhere for the fluid in the lines to go. My field sits at least 2 feet higher than my the top of my tank and the pump sits another 8 ft down inside the tank, the main delivery lines are also 8' into the ground.
/ septic field frozen #34
"If I read his description correct the drain pipe is only 1 1/4" dia. with 1/8" weep holes. After pressure feed and drain back how efficiently that would continue to drain the effluent left in the pipes is questionable at best. If I remember right I had to drill my 3/8" drain holes one every foot over the 40 ft lateral."
I also saw that and thought I'd misread however PIX seemed to confirm.
Have never see or heard of using 1/14", 3" and 4" factory perforated is the norm around here.
Our product (called BNQ.) has 3/8" holes down both sides spaced about 3" apart at the 4 and 8 o'clock positions.
Typical system for 3 BR is 150' of 3" BNQ* using a 750 gal concrete tank.
The field* is generally 5 rows of 30' of BNQ spaced 3' apart and interconnected at both ends using T's and elbows.
This network of piping is laid perfectly level on a 20 ton bed of 3/4" crushed stone and covered by a second load of crush.
A geotextile fabric is used to cover the field followed by topsoil usually enough to blend in with surrounding landscape.
Recently they added dual entry via 2 T's and a vertical vent to atmosphere.
More common now is to also install a grease trap B4 the tank.
Bi annual pumping is done from the tank 1st compartment with liquids being re-inserted.
(personally I prefer total evacuation as the liquid contains suspended solids which in turn flow into the field and clog the soil thus shortening the life)
* a 'percolation test' is a mandatory part of constructing a field.
/ septic field frozen #35
I am going to try and get my sewer sucker guy(new guy this year, the old guy retired) to suck out both halves of the tank. Maybe he will, maybe he wont. Time will tell. I am also going to get him to pump every year.
/ septic field frozen #36
I find it strange that your reputable contractor was not aware of this freezing issue. If he has built these raised mound pressure systems in your area before then he should have been aware of this. The approval authority should also have picked up on this issue during the permitting process. How can professionals that are familiar with the weather conditions in your area not be aware of this issue and the appropriate resolution? I would contact the approval authority and ask them what they suggest, if your contractor is not being helpful.
In any case, with these raised mound systems you do not get as much benefit from the retained heat in the surrounding soil as with a "conventional" gravity system. Therefore you will need more insulation. Look for the weak points in the system, ie what has the least amount of cover and focus on getting more cover over those areas. Is the inspection / cleanout exposed to the surface? If so bury it so that there is not a direct connection from the cold air to your system. I suspect there is very little cover over those black pipe housings too and that would be another area of concern. As someone else already suggested you need to try and retain as much heat form the soil and the effluent as possible. Another thing that works with single pipes (not sure if it would work with a larger area, like your entire field) is to put a poly cover about 6" to 12" above the pipe. This deflects the cold from above, around the pipe. But the best solution is going to be more cover / insulation, with the focus being on the areas that currently have the least amount of cover. Good luck.
/ septic field frozen #37
EDIT; you could also contact the professional that designed the system and ask them for a solution. If the design is faulty they are responsible. However if it is a maintenance issue they should be able to help with a resolution. Were you provided with a system operational and maintenance manual. It is mandatory in our area.
They are aware of the freezing issue, i have been advised by the septic pump operator that he has not seen so many fields freezing in the past it just seems to be because of the new systems and the professionals are more worried about ground protection from the effluent then freezing protection. My contractor has been helpful but he feels he cannot make any changes to the system as it must comply (which it does) it just means more maintenance for me and i need to find a happy medium on coverage during the winter months. I do not have a system operational and maintenance manual but the contractor did come down a tell me everything i need to do to the system.
Another issue that maybe contributing is I am in the wide open field therefore I get little to no wind shelter, my trees are still all young and provide no shelter. I set up a snow fence on the north side of the field and I have about 18" of snow and on the north side i have no snow but i have the bales set up there. So this might be my issue as i discussed before i just might need more frost protection spread out 4' away from my sand mound.
I am just looking for other options I do not want to set up 90+ bales in the fall and have to store them in the spring, dont get me wrong i have no issue doing the labor i just need to make work a little easier, so i thought keep my 90 bales, add heat trace, add insulation, add shurbs etc.
Any thoughts?
/ septic field frozen #40
Are you allowed to put a layer of styrofoam above the field? I guess that might hinder water filtering down...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2011 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2011 FOREST RIVER...
3/8" Quick Attach Blank Plate (A66408)
3/8" Quick Attach...
JOHN DEERE 925F - 25' GRAIN HEAD (A64277)
JOHN DEERE 925F -...
Hedge Posts (A65640)
Pull Behind Sprayer (A65640)
Pull Behind...
