Sensitive loader joystick.
/ Sensitive loader joystick. #1
RickSr
Mahindra Emax 20s HST
Hi, I have a Mahindra emax 20 hst. My question is, my loader joystick is very very sensitive. No matter how careful i am with the movement of the joystick it just wants to jump to whatever i want to do with it. So, i want to know if there is an adjustment somewhere that i can adjust to make it more of a smoother move. TIA, any reasonable response would be appreciated.
/ Sensitive loader joystick. #2
Lower your engine RPM so it lowers the hydraulic flow and makes the loader more controllable.
If this is not enough or you need the high RPM for something else, then you'll need to get a couple flow restrictors.
Ok thanks. I'm going to look under the joystick boot again, the last time I did i tighten everything up and used some lock tight, then packed some grease in there but it acting very touchy again.
Thanks.
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
