4025 Mahindra Loader Valve stuck
/ 4025 Mahindra Loader Valve stuck #1
hayboy48
Bronze Member
West Central Alabama
Mahandria 4025
Last few days my joystick would hang in the down position, had to jerk it pretty hard to get it centered. Yesterday it stuck big time and had to back up to the house. My question is the route to take, remove and clean or replace? Also what to prepare for taking this apart. If I replace, I sure don't want to go to dealer if possible. THANKS AND COME ON SPRING Mahindra 232 loader with maybe 500 hrs.
/ 4025 Mahindra Loader Valve stuck #2
I don't know why no one hasn't jump on this before. I do not know your valve, but the cover on the end of the down spool has a spring in it and 3 or 4 steel balls. The spring might be broken or full of rust and dirt.
/ 4025 Mahindra Loader Valve stuck #3
Does the joystick mount directly to the control valve or is it remote mounted with cables going to the valve? If cables they can and do corrode causing things to bind up. Usually requires replacing the cables.
Direct mount. Got a promise to come clean it for me. A little over my 78 yr old paygrade. Thanks
2018 BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
2018 BRADLEY...
More info coming soon. (A64557)
More info coming...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2018 PETERBILT 567 FLATTOP SLEEPER TRK (A67714)
2018 PETERBILT 567...
PALLET OF HEAVYEQUIPMENT PUMP PARTS (A68842)
PALLET OF...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
