Sensitive loader joystick.
/ Sensitive loader joystick. #1
RickSr
Bronze Member
Mahindra Emax 20s HST
Hi, I have a Mahindra emax 20 hst. My question is, my loader joystick is very very sensitive. No matter how careful i am with the movement of the joystick it just wants to jump to whatever i want to do with it. So, i want to know if there is an adjustment somewhere that i can adjust to make it more of a smoother move. TIA, any reasonable response would be appreciated.
/ Sensitive loader joystick. #2
Lower your engine RPM so it lowers the hydraulic flow and makes the loader more controllable.
If this is not enough or you need the high RPM for something else, then you'll need to get a couple flow restrictors.
Ok thanks. I'm going to look under the joystick boot again, the last time I did i tighten everything up and used some lock tight, then packed some grease in there but it acting very touchy again.
Thanks.
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
More info coming soon (A61569)
More info coming...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
