Self built Mulcher .
/ Self built Mulcher . #42
Hope you took it home Tony
any updates?
I have tack welded the Plasma cut front plate to the machine . This 20mm thick plates takes all the loads the mulcher , chipper and backhoe arm transmit to the machine . I am bidding on a 500amp 3 phase mig welder on ebay at the moment as my current welder isn't big enough to weld 20mm steel .
I bought a marine transmission that can handle 650hp that I am fitting to the rear of the engine . It will give me forward , neutral and reverse .
I can also spin my swinging hammer mulcher in both directions which will allow me to mow light scrub in one pass like a flail mower with the bottom of the rotor forward and in the other direction for heavy scrub in a two way pass method as per the usual method .
The woodchipper has been loaded on the Boat and will be here in 3 weeks .
The fixed tooth mulcher I have decided on is a dual drive Ferri which is extremely well made .
/ Self built Mulcher . #46
Really enjoying the build, you are doing a great job.
Just a bit of a nit pick.
Your hp going through a transmission will be the same (minus gearbox losses)
It will roughly double your torque.
You're right , I should have been speaking of the Torque increase , not HP increase . I have removed the comment .
So 800 odd lbft should get the job done .
Fitted the transmission this afternoon , just need to drill the bell housing bolt holes and bolt it up . Thats another job done , that makes today the 20th day I have worked on it . I would have it going by now if I didn't have so many other things to do , as well as running a business .
I have some fiddly bits ahead of me , I still have to wire up the ECU from the donor truck to get the engine running . I am hoping the donor truck also had cruise control as I will hook that up too . If I put a tone wheel on the output shaft flange on the transmission , I will be able to set the output shaft speed from within the cabin . When the machine hits a tough patch of bush , the cruise control will sense the shaft speed decrease and it will throttle the engine up the same as it would have on the road when the truck hit a hill .
I decided to stop putting off the making of the cover for the aircon evaporator unit I mounted to the ceiling . I made an Aluminium base and covered it with 1/2" foam and Grey vinyl . I mounted the original interior light and the fan/temp control panel in it so it looks pretty stock . UHF radio is mounted on it's right and a small reversing monitor will be mounted on it's left .
/ Self built Mulcher . #52
Hope all is going well with ya.
Figured I'd check in to let you know I check fairly often to see if there are any updates.
/ Self built Mulcher . #53
I just stumbled across this thread today. I am impressed. Can't wait to see the video of this thing in action.
Hello and thank you for your interest . Unfortunately I haven't been near it for a few months . I have been spending all my time getting Cat scans , Xrays etc trying to find out what is going on in my belly .
I will update the thread if I get well and am able to continue .
Thank you also WCD .
I may not be here for a while so I wont be able to reply to any further questions .
Have a good Xmas all and best wishes to you and your families .
/ Self built Mulcher . #56
Hope they get it figured out and you start feeling better!!
Happy Holidays!
/ Self built Mulcher . #57
Get well soon Eagleview! Peace and comfort to you and your family during this Christmas season.
/ Self built Mulcher . #58
That's a huge bugger Reg but you will get better, no ifs or buts. I'm semi retired these days so if you need a TA to give you a hand in the future give me a Hoy. All the very best to and your family.
/ Self built Mulcher . #59
Wow. You have an amazing talent for putting different pieces and parts together to make something that will be really useful. Thanks for sharing.
/ Self built Mulcher . #60
Great project!
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2021 Cub Cadet Ultima ZT1 50in. Zero Turn Mower (A64557)
2021 Cub Cadet...
2001 MACK CXU613 TRI/A DUMP TRUCK (A67148)
2001 MACK CXU613...
(128) BOARDS OF 1"x6"x12" PONDEROSA PINE (A65055)
(128) BOARDS OF...
