selector valve problem
/ selector valve problem #21
If you you have a 17 GPM pump, then you should get 1 gal for every 3.529 sec. or every 15 sec you should get 4.25 gal.
Did you ever wire up the solenoids like I suggested? with the curl cylinder connected to the normally open section. The valve should pass 15 GPM to the curl cyl, with no voltage applied. Of course you don't need 15 GPM to operate the cylinders. The GPM just represents time.
I believe you are supposed to apply voltage before using the curl lever to control the grapple. You can test this off the tractor also.
There may be a condition, where if you move the curl lever before activating the solenoid, that the pressure might prevent the valve from shifting correctly.
/ selector valve problem #22
I have this valve(9-5117-A) on my tractor. I am the one that had the tripple spool with problems. I replaced it with this valve and have had no problems. This valve does not need power to operate the 1st function if it is plumbed correctly.It only needs power to operate the 2nd function.The hoses from the loader control valve go to VE and VR. 1E and 1R go to the bucket cylinders. And 2Eand 2R go to the grapple. Could you have the wrong valve in the right box? Try putting power to it. If it works you have the wrong valve.
Bill
/ selector valve problem #23
One thing I forgot to mention. On the circuit diagram E = extend and R= retract. I dont know if this efects the regen function or not.
Bill
/ selector valve problem #24
Can you explain why you don't need to power the first function, or which solenoid is not powered?
In a valve with NO, and NC spools, The static state is that the normally open spool provides fluid to the curl cylinder in the normal sense of things. and the grapple is not activated, because the spool for that circuit is closed. So, what needs to happen, is for the solenoids to activate to switch fluid flow to the other circuit, which is the grapple. So when you apply 12 v to both solenoids, both spools activate and reverse their positions, and fluid flow is now sent to the grapple cylinder. If you remove the voltage from the solenoids, the spools revert back to their normal positions, which is the curl cyl will now operate, and the grapple will not operate when you move the curl lever.
Can you post the circuit diagram? hydraulic and electrical.
I don't believe this valve has regen. Are you talking about the FEL valve?
/ selector valve problem #25
Hooked_on_HP,
Bill,
The original poster said he has the same valve as you have, and he said he checked out with air. He said that the flow through the valve is not good. He also said he activated both the valves and the solenoids operated the spools to reverse the static state. So, I believe that both solenoids have to be powered at the same time for the valve to be called a diverter valve.
/ selector valve problem #26
The first solenoid is normally open the second is normally closed. This allows the first function to work without any power. When you apply power to both solenoids, #1 closes and #2 opens allowing the second function to work. I went outside and unplugged mine and the loader works as if the valve wasn't installed. I was talking about regen in the loader valve.
Bill
/ selector valve problem #27
Bill,
Did you notice any slow down when you installed the diverter valve. jurden said he thought the flow was less than normal.
i reattached the curl/dump hose with the two jic male adapters and the dump/curl works like it did before adding the valve. i mailed the selector valve back to SC this afternoon. i guess if i had used a little simple math i would have known how to measure the amount in the bucket and the time it took to run-out a gallon. i was just thinking i wouldnt know what 15PGM would look like coming out the end of the hose. anyway...too low a flow through the valve. Ill post up what SC has to say about the valve, they wanted to have it checked out/repaired rather than send another one....i dont know how i would have gotten this far without all the help from everyone. thanks two times!...........al
/ selector valve problem #29
J J , my hydraulics work perfectly. I just did a little research and if he is putting this on his M9000 the hydraulic flow is 23.1gpm acourding to tractor data. My tractor only flows about 7gpm. If this info is correct and I have the right tractor the valave isn't big enough.
Bill
as info my m9000 owners manual shows 64.3 liters/67.9 quarts per min. its a 2006 model....al
i just checked tractordata.com and it does indeed say 23 GPM. i have the owners manual in hand however...al
/ selector valve problem #31
OK, now I am stumped. I thought I had it figured out. I wonder if when they give a max flow for a valve if the are measuring the flow through one port or two. This might be a question to ask SC since this valve is manufactured for them.
Bill
that is a very good point that i had not considered. it may actually flow a total of 15GPM. By having -8 inputs and outputs you (i) would expect more flow than 7.5GPM. maybe your right 15GPM in and 7.5 out the two workports....thanks for the thought...........al
/ selector valve problem #33
What size are the hoses for the loader. The size of the hose can give an idea on how much flow it has. I know it is more money, but SC has the same valve in a larger version.
Bill
FEL hose is 1/2 inch, boom and dump/curl.
/ selector valve problem #35
When you guys hooked up the valve, did the bucket curl rate change any? Even if your pump can pump 17 GPM, most of the time, you are not using the full flow because the time to curl is short, maybe 10 seconds for a full curl. When you say the relief is activated, are you talking about the work port reliefs, or the pump relief?
/ selector valve problem #36
I am thinking like J J .The relief valve on the loader control valve should open before it bogs the engine. I think I would remove the selector valve and hook the hoses back up the way they were originally and see if the loader functions properly. Did you flush your new hoses before you installed them.I am wondering if there is some foreign matter stuck in either the selector valve or the loader control valve.
Bill
what i am hearing is a loud clunk under my right foot, that is the location of the loader valve (cab tractor). as supplied from kubota the dump/curl action is very, very fast. maybe 5 seconds from full curl to full dump and slams aginst the stops. its ok to me if the curl/durl slows down some but not the relief valve opening and the motor trying to stall. as i posted earlier: with the selector valve off the tractor and the dump/curl hose spliced back together with jic/jic unions the loader acts just like it was as supplied from kubota. the restriction is/was the selector valve....al
jj: with the selector valve in place the dump/curl works very slow. maybe 30 seconds from stop to stop, relief valve clunks at the start of movement along with loading the engine hard. all of this has been done with the engine at idle.....al
i blew out the hose with air before i installed them. had the problem, removed hose and blew out with air again, took the selector valve apart and found no trash or casting flash, put it all back together, same problem. started this thread. reattached hose and opperation is normal now without the valve....i still think the valve is bad, wont flow rated GPM, OR is too small for the job........al
/ selector valve problem #39
Al, as you have stated I think you have a bad or to small of a valve. You have eliminated every thing else. I would ask SC for a different valve. I think I would also ask about going to the larger valve.
Bill
/ selector valve problem #40
jurden, Hooked_on_HP
This is just a thought. I seem to remember that some solenoid valves had a manual release on them. Do you remember what the top of the solenoid looks like. Is there a cap, and is there a twist knob of some kind. If it is , screw the spool all the way open, on the grapple circuit. Try working this spool back and forth to the limit. There may be something preventing it from opening all the way, and reducing flow. Did you say that you had taken the spools out and inspected and cleaned them? That relief valve should not be going off for the work port for the FEL, because any flow to the grapple should keep the pressure low enough to keep it from opening.
Have you put a gage in any of the circuits? That will let you see the operating pressure, and the relief pressure. Because all fluid going to the front goes through the FEL valve, I would install the gage in the input to the FEL valve, and leave it there for all future trouble shooting.
2020 DODGE RAM 2500 (A67714)
2020 DODGE RAM...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
PALLET OF DISCHARGE HOSES MISC SIZES (A67714)
PALLET OF...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
1988 BOMAG BW-213PDH-2 SHEEP FOOT ROLLER (A67714)
1988 BOMAG...
