Securing trailer balls
/ Securing trailer balls #41
/ Securing trailer balls #42
/ Securing trailer balls #43
Nope, but trying to convince the injured parties attorney that I did not take reasonable care to prevent a nut from coming off does make me tremble. I usually ask myself if I'm willing to risk losing my home over something (assuming policy limits are exceeded). If you are not willing to invest the time into applying some locktite, then that's your decision. Personally, I've been deposed twice and in both instances the effort that would have been required to prevent the incident was dramatically less that the time that I sat being deposed. It's just not worth the risk.
/ Securing trailer balls #44
Often overlooked is what a loose ball can do... A coworker had his boat and trailer come loose and pass him going down a mountain road. It sheered the ball off, but the analysis showed that it had a loose hole and the ball had been working back and forth constantly for some time. The rust in the break showed that it was not a completely new break.
Clean, inspect (tighten or replace if necessary) and grease. Should be part of periodic maintenance, no less important than checking your brakes or turn signals...
/ Securing trailer balls #46
Never said that I had been sued. Big difference between a deposition and being sued. Read it up.
/ Securing trailer balls #47
Well, I've never been deposed, either - too busy tightening all the nuts and bolts on all my equipment every day.
/ Securing trailer balls #48
Defintly proof that ignorance is bliss.
/ Securing trailer balls #50
So I guess she thing to do is weld the ball all around after tighing.
/ Securing trailer balls #52
Then sell the trailer and put the hitch on the shelf..
/ Securing trailer balls #54
Use a Jam Nut..
Eactly. Stone simple and 200% reliable. No need to go drill pressing and pinning or welding. Like the old Sarge used to say, "Keep It Simple Stupid"
/ Securing trailer balls #56
On the Internet there are so many stupid people that it is no longer safe to assume that obviously stupid suggestions will be taken as humor. Too often, they are dead serious.
I'm glad to know it was an attempt at humor in this case. One less idiot giving advice!
/ Securing trailer balls #57
I don't have a single bar and ball setup with more than 2 to 3 threads showing. No way a jamb nut would work. I bet that's the case with 99% of the bars and balls out there.
Chris
/ Securing trailer balls #58
If it was a wide spread problem, they'd come with cotter pins and castle nuts - the ball manufacturer's lawyers would make them. Like others have said, a little common caution and maintenance and your problems are elsewhere.
I think I am in this camp.
But anything can and does happen. There are many easy solutions. One is the second nut. THis will cost you a dollar or two at TSC for another nut. Being cheap I would go with blue locktite and or bugger up the threads with a chisel for the first few under the nut. It wont come off before you notice, you should start hearing a clunk when accelerating stopping or a bump as the extra gap created as the nut loosens allows the ball to shift around.
At work there is one truck with a cotter pin under the nut. I think this came this way from the factory. If I remember I will try and look at it and get a brand and pic maybe.
Edit Until I got the weight distributing hitch I used one of those dual welded ball and receiver things. No way it could come loose:D
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
2015 Ford F-450 4x4 Crew Cab Landscape Dump Truck (A64556)
2015 Ford F-450...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2018 Takeuchi TL10V2 High Flow Compact Track Loader Skid Steer (A64553)
2018 Takeuchi...
2013 KENWORTH T370 DUMP TRUCK (A64280)
2013 KENWORTH T370...
