securing attachment/implement
/ securing attachment/implement #11
I learned the "secure" lesson when I was 16.
At a summer job at a lumber yard, a co-worker lost an entire pallet load of plywood on a busy intersection in downtown Des Moines. It was not strapped down. My job was to drive the 1 ton flatbed there and load up the plywood with the help of a short, skinny old guy that ran out of juice pretty fast.
/ securing attachment/implement #12
What happened to the co-worker that, he didn't go pick them up? Just wondering. Jon
/ securing attachment/implement #13
It has been over 50 years ago but I think he was running out of time. I think he had a couple more stops to make load on more material before the end of the business day and head home to get unloaded.
/ securing attachment/implement #14
I use 4 chains rather than 2 chains. If 1 brakes 3 will hold things ok enough. If 1 of 2 chains brakes things aren't going to be secured much at all. Machine will go forward or back a bit, then loose lateral support as well as front to back support. Don't cross chain either as the machine can twist & slack all the chains if one comes loose.
I'm a bit more lax on chaining down impliments that are firmly attached to the tractor though. Unattached implements, definitely get chained. But for short 1-5 mile runs I often don't throw a chain over the mower or loader.
I would add that if you happen to have a less than 10k backhoe with a "dipper" with a locking device then the dipper can remain up and need not be chained down.
/ securing attachment/implement #15
From having hauled more TLB's than I can count, I've never hauled one with the backhoe in the air. Even on a "lightweight" backhoe, the tractor will bounce on the tires if the backhoe is not set on the deck.
/ securing attachment/implement #16
My Kubota's owner's manual says to transport the bucket on the deck.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
30KW GENERATOR (A58214)
30KW GENERATOR...
2013 Mercedes Benz E350 AWD Sedan (A59231)
2013 Mercedes Benz...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2006 Nissan Frontier Ext. Cab Pickup Truck (A59230)
2006 Nissan...
FENCE PANELS (A58214)
