Seat switch bypass
/ Seat switch bypass #1
aarolar
Platinum Member
Augusta Ga
Kubota MX4800
Is there a simple non evasive way to bypass the seat switch? Whenever I get on a slight grade I can't stay in the seat well enough to keep it engaged and it's highly annoying. Today I was mowing round the pond and if I tried to look back to watch the mower I just couldn't keep the seat down too light in the pants I guess.
GST here so may or may not be helpful.
/ Seat switch bypass #4
Oh. OK.
The actual seats switch is 3 position. Full pressure (seated), neutral pressure (empty seat), and no pressure (flipped up).
I THINK you'll find that in full pressure the swich is completely open. If this is true, then disconnecting the switch will simulate the seated position all the time.
If this is not correct then trial-and-error jump the non-black wires to the black wire until correct. (sould just be 3 wires)
My problem was that I'd lean right to see the loader better and trigger the safety.
/ Seat switch bypass #5
On my 5240 I unplugged the seat switch and put a jumper in.
Oh. OK.
That's the same thing I'm doing. I can't even take my phone out of my back pocket without it studdering.
/ Seat switch bypass #7
Take Coke can and cut strip to size needed to hold down switch.
/ Seat switch bypass #8
On my BX2230, I just buckle the seat belt ove the seat to keep the seat down.
/ Seat switch bypass #9
Thick chunk of rubber or a wooden block wedged between the mounting bracket that holds the switch and the switch lever works, that's what's on mine. Safety devices are a pain in the a**
/ Seat switch bypass #10
Has anyone done a B2620? I only have clamp on bucket forks and you can't see them while seated.
/ Seat switch bypass #11
Here is the way the wiring works on the L-series seat switch. I would think it would be the same on the other models. There are three wires on the switch (black blue orange) that terminate in male pins in the connector. With the seat only all the way down there should be continuity between the black and orange wire only. With the seat only up there should be continuity between the black and blue wire only.
/ Seat switch bypass #12
On both my BX's I just unplugged the connector, and put in a jumper. Use dilectrict grease and some electrical tape for a waether resistent job.
/ Seat switch bypass #13
My BX switch is a pain too... it did save the tractor when I tipped it by shutting off the engine.
From the stories here of tractor with diesels running on their sides I figured I dodged an expensive repair.
/ Seat switch bypass #14
I do hook my switch up if I work on uneven ground. That doesn't happen often though.
/ Seat switch bypass #15
I just took a cable tie and fixed the problem under the seat of my MX5100. Simple to do.
/ Seat switch bypass #16
Those switches are really simple.
Generally a normally open circuit that needs the switch to 'close' the circuit which then simply wants a jumper to complete the circuitry (or even use tape to close the switch) Weight closes the circuit by closing the switch.
Some might be a closed circuit that wants to be 'opened' by weight in which case unplugging or cutting will dis activate.
I would guess the former is the norm.
Simple enough then I just didn't know how "smart" they may have gotten with them maybe by wiring them into the computer somehow to make it harder to simply bypass by tying it down or unplugging.
/ Seat switch bypass #18
Adjust the seat forward so you can keep your weight over the switch. If you defeat a safety and system and something ever goes wrong, even if it doesn't involve the switch. The jumpered out safety system will be seen in court as a disregard for safety and the well being of others.
/ Seat switch bypass #19
Took 18 posts. 17 more than I would have thought.
Mini Skid Steer (A60352)
Mini Skid Steer...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
YANMAR VIO55-6A EXCAVATOR (A63276)
YANMAR VIO55-6A...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
EZ Trail 3400 (A63688)
