Seat Safety/Kill Switch
/ Seat Safety/Kill Switch #21
On that seat switch one set of contacts is normally closed the other is normally open. I solved my main concern. The PTO does not cut off when I dismount. Putting the parking brake on when I do is a minor inconvenience.
/ Seat Safety/Kill Switch #22
I removed the seat and disconnected the switch. I then cut a piece of plexiglass the same size as the switch and super glued it over the switch and then reinstalled the switch on to the seat reconnected the wire plug and then reinstalled the seat on to the tractor. Problem solved.
/ Seat Safety/Kill Switch #23
Personally I think the seat switch is a good idea but they need 3 points of contact instead of one...the other 2 being closer to each wheel fender. This would make shifting you weight on grades possible.
Unfortunately the switch was made to appease lawyers not operators.
/ Seat Safety/Kill Switch #24
i have an sc2400 it started this morning but now it does not start, i ture the key and all it does is make a quicking sound & its not the battery
/ Seat Safety/Kill Switch #25
Is it a repeated clicking? If so, it is a power issue.
Aaron Z
/ Seat Safety/Kill Switch #26
Please can anybody can tell me how to disconnect seat safety switch on SC2400......must be frozen in the cold weather and tractor keeps shutting off. (please don't respond with why/dangerouse etc...we are all big guys and girls and frustrating that I can't get my mower out of the garage because the government thinks its necessary to put a safety switch on my tractor..)
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
New/Unused Wolverine Quick Attach 72in Grapple Bucket (A65583)
New/Unused...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
