Screw In Tire Studs
/ Screw In Tire Studs #62
Resurrecting this old thread.
I am considering using the Kold Kutter product on my turf tires. Any updates or new information would be appredicated.
/ Screw In Tire Studs #65
I put these Gripstuds in my 16" front tires back in 12/17, they're still in place. I think I put in 110-120 so I still have some left over.
Tire Studs Selection | Grip Studsョ Screw-In Tire Studs | Traction in Ice, Snow and Dirt | Tire Stud Selection
Another satisfied GripStud user here. The Hurlimann has absolutely NO fender clearance to fit chains and wheel spacers would make it worse. The studs work well, fronts and rears.
We get ice, and my place is up a steep hill.
I treat going up and down with a high level of caution studs or chains. (There are chains on two of my other tractors.)
/ Screw In Tire Studs #66
ordered up their 3/4" #10's last year for my FIL
used on his 2310 Yanmar R1 tires
he is very happy with the traction improvement snow blowing on a fairly steep driveway.
/ Screw In Tire Studs #67
With my R4's I am thinking of going with 1/2".
Another thought is to start with the fronts and see how it goes. The road and areas I blow are relatively flat but I get ice occasionally. I drive on concrete in the storage garage, and on the pad in front of the house garage. Those areas do not ice up and I can use 2WD. That way the studs do not tear up the concrete as the front tires are basically rolling along and not spinning.
If I need to have studs on the rear tires, I will invest in horse stall mats for the storage garage. In the past, I used an Ariens blower to clear the house garage pad and can continue to do that if the rear studs are an issue.
/ Screw In Tire Studs #68
Me to, those studs I think are the best with a great selection.
I spent 20 minute online trying to find out what a Hurlimann 435 is, very hard to find good pictures of it. Looks like the tractor is made in Greece or was made, where on here are there pictures on yours?
/ Screw In Tire Studs #69
Here is when I installed the loader valve. All hard lines , took a while.
https://www.tractorbynet.com/forums/hydraulics/289138-hurlimann-loader-valve.html
The Tractor is Italian made. SL&H, SAME, Lamborghini & Hurlimann. All three outfits sold them in different livery with different engine /HP options
Now they go under the D-F banner. I think still offered by all three marques.
Mitsubishi engines (or the Deutz air cooled)
4X3 mechanical transmission
Locking diff both rear and front axles
two speed PTO plus ground speed, mid PTO also
Compact size with good capacity. I hear they are popular in the orchards.
I used mine today to handle logs while working up fuel wood.
I like it a lot. Mine has the folding ROPS behind the seat.
Hurlimann 435 - Google Search
/ Screw In Tire Studs #70
True, but the actual build takes place in Poland...at least it did, last I heard.
SR
/ Screw In Tire Studs #72
/ Screw In Tire Studs #73
I have ice chains on the back which gives wicket traction. Would studding all 4 tires compare to the just the ice chains being on the back. I do about 20 driveways and they are steep and sometimes icy.
/ Screw In Tire Studs #74
The screw in studs have proven to be very effective for me.
I leave them in all year round. But do not drive on any black top pavement. (That would be a mile down the road ;-)
/ Screw In Tire Studs #75
You are very right. I studded all 4 tires and managed some very steep driveways with my L2502. There was once I had to slip some chains on the front tires for one driveway I do. Mind you I don’t have as good of traction but it’s darn good.
2018 GENIE GTH1056 TELESCOPIC FORKLIFT (A60429)
2018 GENIE GTH1056...
2021 CATERPILLAR 299D3XE SKID STEER (A60429)
2021 CATERPILLAR...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A59230)
2017 Autocar...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
2025 IR IRET13 ELECTRIC TRICYCLE (A60430)
2025 IR IRET13...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
