scrapyard box blade...first fabrication project
   / scrapyard box blade...first fabrication project #21
Design looks pretty good but you may want to get a bigger welder to beef up the welds. They look too small and very cold. You wouldn't want all your hard work to come apart if you caught a root or something. I was curious why you mounted the 3 pt. arms so high and on the inside? It would be stronger to have the mounting pins go through the double thickness of the horizontal and vertical attachment points. Even better is to use pins with a mount on each side of the 3 pt. arms. Cutting edges are usually 5/8" or 3/4" thick and 6 or 8 inches wide. You can also get curved cutting edges or straight ones. Better box blades from the factory usually have a recess bent into the moldboard so that when the cutting edge is bolted on, it is flush with the moldboard.
I knew it was just a matter of time before the welding police got on my trail! I was careful to bevel, preheat, and multi-pass the welds. They may not be as strong as they could have been with a bigger welder, but they'll hold until I can get one. One day (hopefully before Spring when I'll be using the BB) I'll be getting a Thermal Arc 211 or 252....until then? I gots what I got.......
   / scrapyard box blade...first fabrication project #23
I just wanted to state that if you have access to it some T1 steel would be more than fine for the cutting edge, no need to buy very expensive actual cutting edge material that bolts on. MY box blade is 13 years old was my 1st ground engaging implement & it is mild steel cutting edge nothing fancy WALLACE brand on close out from Quality Farm & Fleet (prior to bankruptcy.) I think I paid all of 179 bucks out the door, it was setting there long time and was really cheaper to buy the the materials from work. I was working as industrial equipment manufacture at time so had raw steel costs in the 45cent a lb range then. The cutting edge on mine is just some 3/8 structural steel angle iron not even sharpened. It WORKS FINE and I have move a LOT of dirt using it and SNOW as well ;) For the average home owner having fancy cutting edges is not required, now if you plan to maintain 3 or 4 miles of gravel road then ya hardened steel cutting edge would be needed otherwise Steel is Plenty Hard and T1 is a very good upgrade to mild steel A36 stuff.
(Note T1 is more wear resistant and only a slightly harder than A36 but it welds very similar & you can weld it using regular materials...)
Mark
   / scrapyard box blade...first fabrication project #24
Bolt on cutting edges aren't that expensive, especially only 60" wide. Anybody doing snow removal with a skid steer uses bolt on edges because they are relatively inexpensive and easy to replace. They were out a lot faster than on a box blade but it's still good to have an easily replaceable cutting edge. They can be cut with a torch or what ever you have. T-1 steel is a lot higher tensile but isn't used for cutting edges. T-1 is used where you want maximum strength with lighter weight. A simple explanation is that 1/4" T-1 would have the same strength as 1" A-36 mild steel. AR400 is a common wear plate but both do require special welding rods and procedures. I bet getting a piece of T-1 or AR400 cut to size and curved would cost more than a standard bolt on edge. Bolt on edges come with the square counter sunk holes as well. You could check with your county to see if they have some old grader edges kicking around that could be cut to size. Often counties only use one side then discard them. The holes are sometimes offset but they might just give you an old blade or sell it cheap.
As far as the welds, I guess you'll find out. If you used NR211 it's designed for single or multi-pass welds but a lot of the wire sold for those little machines is only designed for single pass welds. One way to look at it is if you were paying someone for it, would you accept those welds? Even when I blew up the pictures, the welds looked too small and not fused very well. 110 volt machines have their place but they just don't have enough oomph for 1/4" and above steel. It's great to build your own projects but sometimes you have to have enough experience and the right tools for the job.
   / scrapyard box blade...first fabrication project #25
Hi again:
Went ahead and took a few more photos of the wallas built box blade I bought 10+ years ago.
click photos for full size.
back corner outside edge, shows the bolt on flat stock, not sure of the material it is not all that hard there are some small nicks probably A36..
inside corner from top
3pt lift arms and shows the inside angle and channel for the drop from the top link down to the back of the box. You can see the close arm where it was all bent up, heated and sledge hammered back into place.
Money shot underneath of the cutting edges bolted to the Angle Iron that is welded between the two upright end plates.
Mark
   / scrapyard box blade...first fabrication project #26
Mark's last picture above clearly shows how to setup the angle iron and bolting on the cutters. If you are concerned about the strength of the angle, you could add triangles as we talked about before. But don't forget to locate and drill your cutter holes before adding the triangles so you don't put them in the way.
   / scrapyard box blade...first fabrication project #27
Great job, Stormpetrel
Question - how did you cut the rectangular holes in the 4X4 RHS? I'd like to do the same but don't have plasma, so they would have to be cut as slots with a cover plate screwed or welded over the open side
Cheers
Alan
Cheers
I cut the rectangular holes in the 1/4" steel with a plasma cutter. If you look around for a while you can probably find a used one at a reasonable price.
Drilling and/or using a jigsaw would have taken forever....so I am very glad I was able to get one for short money...
   / scrapyard box blade...first fabrication project #29
You can also cut them with an acetylene/oxygen torch. They don't have to be exactly precise so a little error with the torch would be acceptable.
   / scrapyard box blade...first fabrication project #30
Yes, Plasma would be the go. but my use for that would be limited, so it might be better to get the local engineering shop to cut the holes. What do you think about my alternative suggestion to cut U-shaped slots, insert the tines and bolt on a heavy cover plate?
Love your comment about the "welding police." I work in the bush with a 10KVA generator and 120A stick welder and a mate says my welds look as though they were done with a knife and fork!
Cheers from Oz
Alan
   / scrapyard box blade...first fabrication project #31
You can cut the slots with either the plasma or gas torch, consider adding the reinforcements regardless which will both strengthen the slots and make a neat appearance.
My policy is to farm out machining only when necessary, while I would hire a machine shop to cut a key way and mill a head the simple cut and notch stuff I like to do myself.
   / scrapyard box blade...first fabrication project #32
Me too. I built my shop wood stove several years ago without a cutting torch. Used my stick welder to make all the cuts including cutting a 24" diameter piece of pipe for the barrel.
   / scrapyard box blade...first fabrication project #33
Thanks - I looked up more info about using a stick welder with the amps cranked right up to make the cut. That should work fine.
Regardless, thanks for feedback on the reinforcement That will strengthen the job greatly.
Cheers
Alan
Cheers from Oz
Alan
I think your idea would work great!
As far as the welding police....my first couple of projects have been "heavy" fabrication (for a teensy-weensy welder) and I have had good luck. That all went out the window when I started to build a cart for my welder & plasma cutter today. I am very finicky about clean, beveled surfaces with good fitment. AND......I remember reading somewhere about tack-welding stuff first. But I either forgot about that, or figured it didn't really apply to me. So my cart frame is a little warped!!!:eek:
I guess I'll adjust the height of the wheels a little bit to account for the warpage, and no one will be the wiser:laughing:
One last thing: I bought a 7&1/4" metal blade for a skil saw, intending to use it to cut 1/4" plate steel. I never used it because I got the old beat up plasma cutter going good. I found an old 8&1/4" Hitachi slide saw in my attic and put the blade on it. Instant metal saw!! It did the 1" square tube and 1" angle iron cuts beautifully!!:dance1:
   / scrapyard box blade...first fabrication project #35
Someone with more technical knowledge than I might explain this, but, a MIG welder will distort and pull metal REAL BAD. Way worse than a stick welder. You gotta tack everything, at each corner, several times at a splice, varying the tacks, one side, then the other side, then back to the first side, several times to get it to stay in place. I've even had tacks break when welding on the opposite side. I messed up plenty of projects in the beginning with a MIG welder. I had always welded with a Lincoln stick welder before. Don't feel bad. Think of it as a learning curve!!! You aren't experiencing anything everyone else didn't experience. At least you are honest and modest enough to admit it!!! :thumbsup:
   / scrapyard box blade...first fabrication project #36
I would personally buy a cheap cutting edge off a KK or something, I definitely think there is an advantage to a curved cutting edge. Box blade looks great though! :)
Without having a plasma, I believe you could easily cut those holes in 2" tube with a recip saw or even better, a small metal cutting bandsaw, and a cutoff wheel. Cut the top/bottom slots, and then use the wheel to cut the front/back. You could then weld up the overage from the cutoff wheel.
I like the way your locks are done for the shanks... the cheap KK I have is fine except those are very small pieces of metal a pin sticks into against the steel tube. Your method looks a lot better and not much more work/money! :)
   / scrapyard box blade...first fabrication project #37
I love your box blade, and I'm really impressed with your fabrication skills. I will make two suggestions:
1. As others have suggested, commercial blades have reinforcement on the back wall to stiffen it. A piece of angle-iron welded across the top of the back, at least, but something along the bottom as others have suggested would also be good. On mine, the back wall has just been bent to a right-angle at the top, in a brake, but that's probably not something you can accomplish, especially after the fact.
2. The most obvious weak spot in your design is the central "down-tube" (that's what it would be on a bike) on the three-point frame. At the VERY least, you should rotate that piece ninety degrees along its long axis. Most of the stress on the blade will be trying to torque the back of the blade down and towards the front of the tractor, around the lower lift pins. This torque is opposed by that "down-tube", but as you can see, if you have that piece of stock flat, it's very weak in resisting that force, since it wants to bend along its flat direction, and is very stiff along its tall direction. On my box blade, there are actually two of that piece, running left and right of center, and they are oriented up-and-down, not flat. Alternatively, you could replace the piece of flat stock with a piece of tubing. If you do any of this, do it after welding the angle iron to the top of the back wall, since that'll change your measurements.
   / scrapyard box blade...first fabrication project #38
Don't try to cut the slots for the rippers by turning up a stick welder. You'll make a heck of a mess and it will be hard to clean it all up. If you don't have a cutting torch or a plasma, drill a hole at each end and then either drill more holes in between or just the cut out between the holes. A recip. saw or jig saw could do this. Even if you have a torch, drilling the ends of the slot is a good idea and then use a straight edge for your torch to cut out between the holes. Be sure the tip is real clean. Maybe a small zip disc in a grinder would cut the slot too? If it cut a little further than you wanted, just fill the gouge in with weld and grind it flat. It wouldn't affect strength. If the corners at each end of the slot have to be square, and not rounded from drilling, that's easily accomplished with a saw or grinder as well. I think my shanks have a curve to them.
MIG welding should actually lessen warping because it's a faster process with less heat input than say stick welding. That's why it's so popular for auto body work. The reason you seem to get more warpage with MIG is because it's the best process to use for thin sections. Sometimes you have take steps to combat warping like not welding all in the same place at once or clamping a heavier piece on the backside of the piece your welding, etc.
   / scrapyard box blade...first fabrication project #39
Thanks Arcweld. Good advice
Most cuts I make in metal are done with ultra-thin grinder blades and I can't see any reason why the "fore and aft" cuts can't be done that way. It wouldn't be too difficult to make the last cut also with the grinder because Stormpetrel's vertical "tabs" and an extension of the weld would cover any overcut anyway. The reinforcement on the forward edgeas noted by others will help greatly to stiffen the whole assembly.
   / scrapyard box blade...first fabrication project #40
Not to distract from this build, but since we are talking about scarifier toolbars and their design, I want to show you these pictures.
First one is of the scarifier toolbar on the John Deere road grader I run. This is with the scarifiers installed.
Next picture shows a scarifier removed. If you look closely at the tooth you can see it has notches in the rear edge. The slot in the toolbar is big enough for the tooth to drop thru. When you get it at the height you want you push it rearward locking it in one of the notches. Then you drop the curved pin in front of the tooth. This prevents it from getting out of the slot. When the tooth is used the force pushes it tight against the pin so there's no chance of it coming out and the tooth is still engaged in the slot. Very simple to change height or remove teeth. No tools required. I always thought if I was building a toolbar with scarifiers, this is how I'd fasten them in.
2016 BOBCAT T590 SKID STEER (A60429)
2016 BOBCAT T590...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
bad boy zero turn 72 (A56859)
bad boy zero turn...
Crown RM6025-45 Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
