Rear Blade Scraper Blade Choice
/ Scraper Blade Choice #21
Thanks to all. My tractor is 7 to 8000# and I expect to do a lot of ditching and leveling areas. I do not expect to be taking anything more than a "light" cut meaning an inch or so at a time. The soil varies from "squishy" to "concrete" depending on it's moisture content, so having the blade available at the right time is important. From all the input I've received, I think anything more than 1000# blade will be to much for my tractor and anything less isn't enough. I've used the light (200# - 300#) box and angle blades before and they were just to light.
I do have one area that I need to remove the top 4" of soil. I will see how the blade works with that (multiple passes). I can always use my tiller to break it up first if I need to.
I'm fairly certain that the top soil will be no problem to deal with. :thumbsup:
The Land Pride RBT35 series blades are a very good all around blade IMO. They and others similar to them are a very good implement for tractors in the 4500lb-9500lb range. Obviously the heavier tractor can get the highest capabilities out of the blade, but they still work very well with the lighter tractors. I know that some day I hope to get an RBT3584 for my 5000lb tractor. :drool:
/ Scraper Blade Choice #22
Unless your soil is actually concrete, if you get the blades mentioned on here that weigh in ~1000 lbs, I can near promise you, you will not need to till first. They will dig and cut. As Brian said, it's all about "how much at a time" and that's a function of your tractor more then the blade (well, to a certain point). I know my blade could dig more/faster with a bigger tractor, the limit is the mule, not the blade itself. If you've seen (as I have) cheapo blades bouncing along the surface unable to cut, well, that's not gonna happen with one of these larger blades. I posted some videos using mine, I think that'll set your mind at ease, no tilling necessary unless your trying to break concrete. ;)
/ Scraper Blade Choice #23
At least now I know why I never moved the rock!!
I can understand why also!!!
David from jax
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
Towable Trash Pump (A59228)
Towable Trash Pump...
2016 Ford Fusion SE Sedan (A59231)
2016 Ford Fusion...
GEARMATIC WINCH (A58214)
GEARMATIC WINCH...
Bobcat mid mount mower M60-5 60" CT2025
Bobcat mid mount...
