MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,704
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Thanks to all. My tractor is 7 to 8000# and I expect to do a lot of ditching and leveling areas. I do not expect to be taking anything more than a "light" cut meaning an inch or so at a time. The soil varies from "squishy" to "concrete" depending on it's moisture content, so having the blade available at the right time is important. From all the input I've received, I think anything more than 1000# blade will be to much for my tractor and anything less isn't enough. I've used the light (200# - 300#) box and angle blades before and they were just to light.
I do have one area that I need to remove the top 4" of soil. I will see how the blade works with that (multiple passes). I can always use my tiller to break it up first if I need to.
I'm fairly certain that the top soil will be no problem to deal with. :thumbsup:
The Land Pride RBT35 series blades are a very good all around blade IMO. They and others similar to them are a very good implement for tractors in the 4500lb-9500lb range. Obviously the heavier tractor can get the highest capabilities out of the blade, but they still work very well with the lighter tractors. I know that some day I hope to get an RBT3584 for my 5000lb tractor. :drool:
