Satoh s370d beaver.
/ Satoh s370d beaver. #1
james waters
whitesville,ny
yanmar 1500
Just got this tractor. Battery was bad put a new one in it and it seems to be a hard starter. I finally got a pull start and tractor seems to run great. Question is how to make it start easier. There is a glow plug indicator on dash that lights up after key is turned backwards for several second. Could the glow plugs be bad. Also i see fuel leaks in the return line at top of injectors. What else can i do. How do i time a deisal and what should the compression be.
/ Satoh s370d beaver. #2
I will try to help. I do have a beaver but haven't started it in a few years. I do remember it did not like cold weather very much. I would hold the plugs on for about 30 seconds hit the starter and if she didn't hit fairly quick, I would cycle glow plugs for another 30 seconds. Sometimes it would take three or four tries, but it always fired off. As far as the fuel leaks, I would repair those as soon as I could. Timing should not be an issue. I do have a service manual somewhere and could look up compression for you providing I can find the manual. Mine was starting to burn a little oil but not bad. I broke the output sector shaft on the steering box and that is why I parked it. Great little tractor! Enjoy.
Hey thankyou. I ordered the oem service manual
Also when i got home i turned on glow plugs and when the indicator was clear i counted 30 second and after some cranking it took off. So that was a big win win there. So now i will try usi g the glow plugs more then once to see if i can start it easier( less cranking). It does run great now to fix the little things here and there
/ Satoh s370d beaver. #4
Great! Glad to hear you got it running. One day, I am going to get mine going again and will need your help. :thumbsup:
Thank you again and question ever read anything about adding power steering to the beaver
/ Satoh s370d beaver. #6
Have a Mitsubishi MT180D, very similar to your s370d, good tractor.
IMHO ranks with Kubota quality.
As to cold starts, mine is plugged in with block heater and I also re cycle the glow plugs when it is very cold.
I am also in the process of adding power steering (when I find the time) and have most components on hand to do so, (LOL like 3 years now).
/ Satoh s370d beaver. #7
The Mitsubishi needs to be glow plugged even when it is warm out. I can supply the major components to add powersteering.
/ Satoh s370d beaver. #9
email me for pricing.
/ Satoh s370d beaver. #10
Compression should be 455psi, but it should start and run fine down to 375psi ive been told.
2" X 2" DIAMOND BAR W/ SHANKS (A63291)
2" X 2" DIAMOND...
Champion Vibratory Roller (A60462)
Champion Vibratory...
Transfer tank (A61567)
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
1996 INTERNATIONAL 4800 SPREADER TRUCK (A63291)
1996 INTERNATIONAL...
1061 (A63291)
1061 (A63291)
