Satoh Bison s650g problem
/ Satoh Bison s650g problem #1
SatohBison1987
Satoh Bison S650g
Alright here is my deal, everything is fine with the tractor except that it wants to bog down when driving up hills and even on flat ground sometimes even if I run the RPMs high. I'm really not sure what the deal is I have changed the plugs, wires, etc. Any ideas will be greatly appreciated.
Thanks!
/ Satoh Bison s650g problem #2
I think I would suspect a fuel pressure/ filter issue based on symptom may want to inspect the fuel supply hoses and lines for splits or cracking etc. also. Good luck
Thanks so much..That's what I will do! See what happens
/ Satoh Bison s650g problem #4
Thanks!
You might check the governor
(2) KMC Strip Till Row Markers (A64127)
(2) KMC Strip Till...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
Deere 670G (A64126)
Deere 670G (A64126)
2023 Bobcat T86 (A64126)
2023 Bobcat T86...
Case SV280B (A60462)
