rusting tools in tool boxes
/ rusting tools in tool boxes #1
jay3534
zebulon nc
AC 5015
What are you using in your tool boxes to prevent rusting tools? Tool boxes are in a storage building and I wipe tools off after use. Light oiling is not preferred.
/ rusting tools in tool boxes #2
Rusting is from moisture/condensation. I had the same problem. Insulation applied to the roof and walls cured it for the most part.
/ rusting tools in tool boxes #3
Dissicant
A dehumidifier
I spray just a little WD-40 in a drawer full of tools occasionally.
/ rusting tools in tool boxes #4
Light oiling is not preferred, but might be necessary. If you're not going to do climate control in the storage building to prevent humidity, it's about the only choice, except putting them in sealed containers with a desiccant.
When I brought home my tools/toolbox from my last job when production got outsourced, I stored them in the unheated garage. Within a couple months, all non-chromed tools, like pliers, pry bars, hammers, etc. started developing rust.
Take a rag with some WD40 and wipe them down each time you're done using them. Doesn't have to be a thick coat. It also gives you an opportunity to show them some love and inspect them for damage/condition.
/ rusting tools in tool boxes #5
For our horse tack room and the garage bathroom I bought two small dehumidifiers from Amazon. They have a small pull out water collection container at bottom. I drilled a hole and threaded in a small hose adapter, putting JB Weld on threads. Then aquarium tubing going outside, 3/8" hole drilled through wall. They work well & never have to empty container.
/ rusting tools in tool boxes #6
Fluid Film.
In Mississippi EVERYTHING rusts. I've ~5,000 sq ft of "shed space" spread throughout 4 buildings. Early on I bought a case of Fluid Film in their aerosol cans and spread them throughout the buildings. Any sign of bare or scratched metal gets squirted.
/ rusting tools in tool boxes #8
Has anybody tried Zerust? Our maintenance guys used to put them in control panels that were prone to rust.
/ rusting tools in tool boxes #9
I use desiccant packets in all my socket sets and in all my tool chest drawers. Sometimes I wipe some with Fluid Film.
/ rusting tools in tool boxes #10
For many years I thought tool manufacturers are missing business by not making stainless steel tools.
Then I realized they wouldn't sell replacement tool nearly as often.
Bruce
/ rusting tools in tool boxes #12
I'm in a similar situation. Workshop is a detached, not normally heated outbuilding. There is a woodstove for when I want to work out there in the winter, but it takes several hours to bring it up to a comfortable temperature if it's below 20 or so which limits my winter projects considerably. Hand tools generally aren't a problem, though as others have suggested an occasional wipe-down with light oil or FF helps. Table saw and drill press have developed some surface rust, not really problematic on the drill but a PITA on the saw. Haven't really come up with a good solution to that other than cleaning it with a wire brush or steel wool and using paraffin when needed. Don't really want to oil the saw...
/ rusting tools in tool boxes #13
Use paste wax on your saw. ;)
/ rusting tools in tool boxes #14
Dehumidifier is what you need.
Size according to garage size. Drain outside so you don't have to keep up with emptying it.
/ rusting tools in tool boxes #16
Fluid Film.
Really? Now, I've never been to Mississippi so forgive my ignorance, but the parts of the South the Mainer has visited rust was rare. I never would have thought of Mississippi as a place with a heavy rust presence.
/ rusting tools in tool boxes #17
Hmmm. I think that being warm, humid, with lots of rain, daily temperature fluctuations, near the dew point, all make it perfect for rust.
I think unless you have the metal in a conditioned space, it happens pretty much everywhere, though certainly slower in dry climates.
All the best,
Peter
/ rusting tools in tool boxes #18
All the best,
Peter
Not a climate I'm particularly familiar with, and haven't really experienced. My extended time in the South consisted of South Carolina and Texas, and I saw little rust in either place. So between that and my default to correlating rust and Maine winter combined with ocean salt, it just did not occur to me how humid and therefore rusty a place like Mississippi would be.
Ignorance on my part.
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
GEN POWER 40KW GENERATOR (A64278)
GEN POWER 40KW...
Rooster (A64557)
Rooster (A64557)
2017 GENIE S-40 TELESCOPIC BOOM LIFT (A65053)
2017 GENIE S-40...
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
