Rpms for backhoe
/ Rpms for backhoe #61
I built my first septic tank using 8X16 cement block
and that's over 35 years ago still working and no
problems and never pumped it either as solids dissolve thay's why we use yeast!
willy
By definition you built a cesspool!
Septic tanks are sealed and have no leakage.
/ Rpms for backhoe #62
Are you telling me that septic tanks don't use
a drain field?
You can buy cement septic tanks and they use
a drain field. A perk test is preformed before you
build a septic system!
Fried 1765 you live in the city??
If you live in the county must have one hell of a
pumping bill for pumping out your sealed septic
tank!
You can say anything you like but my system works!
willy
/ Rpms for backhoe #63
a drain field?
tank!
willy
In post #61 I said ABSOLUTELY NOTHING about septic tanks not requiring a drain field!
I have no guess as to how you came up with that conclusion.
I am a former Civil engineer!
I think I know just a little bit about how septic systems are designed, installed, and how they work.
All septic tanks SHOULD be sealed, and should not leak, as I described above!
Liquid effluent is then discharged from the septic tank, (frequently by gravity) through a distribution box, and out to a drain field!
I have personally lived with a cesspool (now generally illegal), or a septic system, since 1940!
2011 Kenworth T400 33Yd. Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
520/85R46 MICHELIN TIRE (A64278)
520/85R46 MICHELIN...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Land Hero Mini Skidsteer (A66408)
Land Hero Mini...
