Oil & Fuel Routine Maintenance
/ Routine Maintenance #1
GDawson
Yanmar3220D, NH3830, Ford5000
I am going to change the fuel and hydraulic filters on my 3220D. Does anyone know of a website where I can access the correct procedures to accomplish this?
/ Routine Maintenance #2
Here is a good one on fuel filter. Yanmar Tractor Fuel Filter Change
Don't know of a similar on hydraulics. Not familiar with the 3220 but I would assume it has a screen, most likely found behind a 3 bolt flange low down on the transmission someplace. You will need to remove drain plug or plugs and drain fluid. No idea how much a 3220 holds. I would expect at least 5 gallons so be ready with pans, buckets or whatever. I believe you also have a spin on hydraulic filter that will need to be changed. Watch the condition of the fluid and screen, if real bad you might want to rinse out a little with a cheaper fluid. You will want to refill with Fluid & Oil Types Hope this helps you some. Maybe someone with direct knowledge of a 3220 will come along.
2006 Hummer H3 4x4 SUV (A66738)
2006 Hummer H3 4x4...
2016 Kia Rio Sedan (A66738)
2016 Kia Rio Sedan...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
More info coming soon. (A64557)
More info coming...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
