Oil & Fuel Routine Maintenance
/ Routine Maintenance #1
GDawson
Yanmar3220D, NH3830, Ford5000
I am going to change the fuel and hydraulic filters on my 3220D. Does anyone know of a website where I can access the correct procedures to accomplish this?
/ Routine Maintenance #2
Here is a good one on fuel filter. Yanmar Tractor Fuel Filter Change
Don't know of a similar on hydraulics. Not familiar with the 3220 but I would assume it has a screen, most likely found behind a 3 bolt flange low down on the transmission someplace. You will need to remove drain plug or plugs and drain fluid. No idea how much a 3220 holds. I would expect at least 5 gallons so be ready with pans, buckets or whatever. I believe you also have a spin on hydraulic filter that will need to be changed. Watch the condition of the fluid and screen, if real bad you might want to rinse out a little with a cheaper fluid. You will want to refill with Fluid & Oil Types Hope this helps you some. Maybe someone with direct knowledge of a 3220 will come along.
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A67148)
2010 HINO 268 4X2...
