Rounded off drain plug
/ Rounded off drain plug #1,941
Award for wha,,,,,,,,,,,,Oh yea, screw up of the year award!
Now, now. Ol Kando toyed around with us for the longest time, giving us every opportunity to post the exact solution. And when the thread post count per month waned he took the solution into his own hands and.....
WHOOMP, THERE IT IS....
Kando needs to go down in TBN history as the man who beat us all :thumbsup:
We still need to know who won the chicken dinner, who was the closest to the solution Kando used to ...Git er done... :confused3:
/ Rounded off drain plug #1,942
i think the drain plug has been beat to death
/ Rounded off drain plug #1,943
I dont think he beat it out.......
/ Rounded off drain plug #1,945
A long with needing to get to 2000
/ Rounded off drain plug #1,946
/ Rounded off drain plug #1,949
/ Rounded off drain plug #1,952
The head of the plug was cut off before we drilled through it, after drilling we chiseled away the rest and cleaned it up flush to the pan. After that tapped the easy out into the hole and started turning. Came out smooth after all that.
What did you use to cut off the plug?
/ Rounded off drain plug #1,953
I'm a bit late, but thank you Kando for providing us with the entertainment for the last year +.
:thumbsup:
/ Rounded off drain plug #1,956
Epic thread.
Yeah, I skipped a page or two.
Say it is not so! There is a lot to learn in this thread, if you ever have a stuck drain plug this is the thread to research. Thesis material it is :thumbsup:
/ Rounded off drain plug #1,958
/ Rounded off drain plug #1,960
Maybe, if you figure out how difficult it will be to get that cross bar back in place and if any additional help or tools will be needed.
I have a 3' pipe wrench, mention long ago, that should work. Proper tool for the proper job.
ONAN 6.5KW GENERATOR (A64281)
ONAN 6.5KW...
42" X 21' ADS DRAINAGE PIPE (A64281)
42" X 21' ADS...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
