Rounded off drain plug
/ Rounded off drain plug #1,161
Now that we have unsuccessfully unstuck a drain plug and a light bulb, does anyone have anything else that is stuck that we cannot agree how to unstick? :confused3:
Bad relationship with a sibling
/ Rounded off drain plug #1,162
We seem to be in the middle of a sticky wicket...
/ Rounded off drain plug #1,163
you probably have to push it in a tiny bit more. you can buy this. https://www.amazon.com/Extractor-Br...45199914&sr=8-2&keywords=broken+key+extractor or make one from a hacksaw blade by grinding, just be sure to keep the blade cool so you don't take the temper out!(grind,cool, repeat).. a hard steel wire with a hook on it can be tried too..
The key is not broken. The end is still on it. I think the tumblers in the cylinder have fell out of place and locked the key.
/ Rounded off drain plug #1,165
I had one of those at one time. Unfortunately he very suddenly passed away. Speaking from experience it's kind of a rough way to deal with it, not that I had any choice. Best mend fences sooner rather than later and yes you can quote me to your sibling.
/ Rounded off drain plug #1,167
Gently pull the key while tapping it.
Look up "bump key"
Bruce
/ Rounded off drain plug #1,168
This has worked for me in the past: Penetrating oil, vise grips and light taps with a slide hammer.
/ Rounded off drain plug #1,169
Even if the key was out I still don’t have a working cylinder and it requires turning to the on position to get the cylinder out which it won’t do. I think I’ll have to drill it out.
/ Rounded off drain plug #1,170
Take the electrical switch off the back and use a screwdriver to turn it to the proper position? I imagine that if you tried what was suggested previously with a vice grips and a slide hammer, then put the biggest flathead screwdriver you can fit into the key slot and turn it with a pair of pliers (or an adjustable wrench if the shank on the screwdriver is amenable to it) it will turn to the on position and work well enough for you to remove the lock.
Aaron Z
/ Rounded off drain plug #1,171
Wonder if just the right amount (tiny amt) of super glue on broken key would hold long enough to pull it out?
/ Rounded off drain plug #1,172
I don’t think it’s broken. Just stuck.
/ Rounded off drain plug #1,173
/ Rounded off drain plug #1,177
I’ve since got the key out. The cylinder still won’t turn. The cylinder has to turn to take it out in one piece. Otherwise you could carry a new cylinder with a key and jerk the plastic off and be underway in your stolen vehicle in 5 minuets. ( you can bust the cylinder out and still be under way pretty quick )
Did you do the WD40/tapping/turning thing in the video?
/ Rounded off drain plug #1,178
Did you fabricate that? That's a useful device!
No, I’m not smart enough for that. The vise grip adapter came with the slide hammer.
/ Rounded off drain plug #1,179
No it came out with less drastic measures but the lock cylinder is still stuck.
CASE INTERNATIONAL 2208 - 8R30" CORN HEAD (A63291)
CASE INTERNATIONAL...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
YALE FORKLIFT (A63291)
2017 CATERPILLAR 980M WHEEL LOADER (A64279)
2017 CATERPILLAR...
