Rounded off drain plug
/ Rounded off drain plug #743
Either will do in this case. He has a horizontal bar right below the drain plug ....
Ah ha, then the right angle Phillips head stripper is the ultimate tool. :thumbsup:
/ Rounded off drain plug #744
I'm going to talk to a small welding/repair shop down the road about removing that plug. Any attempts I make simply end up stripping it bit by bit more. There's a bar that runs underneath the tractor side to side connecting to the FEL mounting and it sits directly underneath that plug with about 1ス" of space between it and the plug head.
This was post #28 from Kando and is still one I like a lot. Have them make a house call and pay attention while they are doing it. They will view this as easy-peasy and aren't likely to charge very much. Certainly the value of having things go right has merit.
/ Rounded off drain plug #745
I have been wondering why he got away from this idea. While he has received some good and not so good suggestions for future reference, they all are just behind the 8-ball . Rather than continuing to make things worse, your suggestion is the best for this time around.
and it probably won't cost much more than all of the tools we are suggesting that he purchase.
/ Rounded off drain plug #746
/ Rounded off drain plug #747
Wow this is how everyone gets so many posts #. I’ve been going about this all wrong. alrighty then I learned something new today. PS pipe wrench got my vote good luck.
/ Rounded off drain plug #748
This 36 inch aluminum is what I would use:
/ Rounded off drain plug #749
This thread should prompt new additions to the Urban Dictionary.
One man's rounded plug is another man's entertainment.
Up your's with a rounded plug.
And the majority favorite,1 rounded plug is worth 1,000 posts.
/ Rounded off drain plug #750
Only 246 posts to go!
/ Rounded off drain plug #751
We could easily find ways to make up the last 10 posts. ;)
/ Rounded off drain plug #752
once again a thread can prove beyond any doubt that there is nothing one can do about getting older but immaturity is immortal...!
/ Rounded off drain plug #753
/ Rounded off drain plug #754
Kando is going to run us up to 990 and then fix the plug just to get us back
There will be more than 10 posts telling Kando he removed it the wrong way and should put it back and take it out to prove MY way is better.:confused3:
/ Rounded off drain plug #755
Okay I am joining in the madness... have been following this thread since near beginning wondering why a clean sharp (new) pipe wrench hasn't finished this job many moons ago. I am rooting for you, Kando... please end this saga!
/ Rounded off drain plug #756
Given the small length and diameter of what's left of the drain plug, I'm not so sure that that 8" wrench with a cheater isn't a better option than a 36" pipe wrench. In any case, the new sharp teeth of a new wrench will be your best hope short of using a welder. In my experience, I've had better luck with smaller pipe wrenches on smaller diameter pipes and larger pipe wrenches on larger diameter pipes.
It might feel more manly to go all caveman all the time, but sometimes finesses is more important than size :)
/ Rounded off drain plug #757
The most important thing is adjusting the jaws for maximum squeeze.
If wrong the sliding jaw will hit the edge of the fixed jaw and quit squeezing. :eek:
/ Rounded off drain plug #758
Growing up and acting all mature is vastly over rated.
I'm having a great time retired and playing with all the toys I couldn't afford 40 years ago. :thumbsup:
/ Rounded off drain plug #759
Just don't let the Fun Police catch you at it!
/ Rounded off drain plug #760
Yup. Growing old is mandatory; growing up is optional.
Psychologists say the happiest people are those who can lighten up and poke fun at themselves and the things that surround them. Count me in.
karcher pressure washer (A61567)
karcher pressure...
CONE BOTTOM HAY FEEDER (A63291)
CONE BOTTOM HAY...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
