Rounded off drain plug
/ Rounded off drain plug #581
I've got a Ford 5000 being delivered in the morning. I'll get a couple pictures when I'm moving things around.
Still waiting! :D
I know, I'm worse than a kid at Christmas. (Is that Carly Simon I hear singing in the background? Anticipa-tion...)
You wouldn't necessarily need to get it hot enough to burn it out. A portable hand propane torch on the plug, not the pan is what you would want to heat in that case, just a little bit to expand it will often be all that it takes..
At this point though that probably isn't what you want to spend time on, about the time that you do get back to work on it. The next time you crawl underneath it should be the time that you get the job done.
A drain pan is a lot lighter weight than a bolt and would absorb the heat faster than the drain plug. Heck, even I can burn a nut off a bolt.
I feel I must explain, that post was meant as a joke.
As for the pictures, the tractor ended up being delivered 3 hours late and it was sleeting at the time.
/ Rounded off drain plug #583
Don't take everything that I post so literally... especially on your thread here, as we all are just joking around while waiting to see how you resolve it. If I was a better mechanic I would pay you a visit... I'm long overdue for a good road trip.
I was threatening to burn the bad fuel out of my nearly new Kubota with my 100,000 BTU torch... and while I wouldn't have done it I was NOT joking when I said it.
We all enjoy pictures, but I don't believe that I have any posted of my tractors, either. I just want to see how similar that Ford is to the one in my family's barn.
No worries, I just wasn't expecting any serious responses to that post.
If the weather is decent in the morning I'll try and pull the 960 out and get some pics. Overdue for a start and warm up anyway.
Trying to diagnose a starting issue with the 5000 I got recently, but that's for another thread.
/ Rounded off drain plug #585
I wish there was a TBN member in northern Indiana who could toss some tools in there truck and head over to Kando's place for a project. Maybe even someone who had a small welder they could take along.
/ Rounded off drain plug #586
My list for Kando's drain plug project.
One vise,one floor jack,two jack stands,one package of JB Weld,one oxy/acetylene cutting torch,one small pipe wrench,one large pipe wrench,one long cheater pipe,one box end wrench,one Lincoln HD140 and and a spool of Innerdhield NR 211MP. Have I overlooked anything? Oh wait,gotta have a six pack for this "hold my beer project"and smart phone to document for U-Tube. :blacksmith::tractor:
/ Rounded off drain plug #587
Anybody ever try one of these:
vintage-universal-wrench-adjustable-no-201-3-8-9-14mm-13-16-quot-15-22mm-quot-aaa8f7f19900f5589209c1c4c3aa40e4.jpg
I don't even know if they're still sold. The concept was sort of like a pipe wrench, more pulling force tightened up on the bolt/nut.
/ Rounded off drain plug #588
Hacksaw to remove that crossmember; angle grinder to square the nut back up; small propane torch to gently heat the oil pan and expand it; welder and iron stock to replace the crossmember with something which is removable. And of course the liquid refreshment mentioned above.
/ Rounded off drain plug #589
Hey look at that nut,bolt and plug rounder offer.
/ Rounded off drain plug #590
I see this version now, as well as one with a serrated jaw:
Not sure how much torque they'd take, but how much torque would be needed for this plug once you got a good grip?
/ Rounded off drain plug #591
I see an absolute zero chance of that tool working for Kando.
/ Rounded off drain plug #594
I still think I could do it with just a pipe wrench.
Seen alot worse, conquered alot worse.
Pictures as promised. Finger for attempted reference.
/ Rounded off drain plug #596
A small pipe wrench held flush with the bottom of the case should grip the threaded part enough to get it out. It looks like a standard barrel vent plug would fit, one that has the square hole for a flex handle is what should have been in there to begin with.
/ Rounded off drain plug #597
Pipe wrench was the first suggestion, 60 pages ago. That's why it looks like it does.
/ Rounded off drain plug #598
I think the OPs pipe wrench is junk. A pipe wrench with sharp teeth would get that out.
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
John Deere Z997R (A60462)
John Deere Z997R...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61574)
2014 Crossroads RV...
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
