Rounded off drain plug
/ Rounded off drain plug #1,811
I am fairly sure it is cast iron based on the pic
/ Rounded off drain plug #1,812
I don't recall; and am not inclined to search 1800 posts. Does anyone recall if Kando or others mentioned what the sump material is? Sheet material or cast? Totally different approach. Are we back on track?
Ron
Yes. It is the transmission, cast.
/ Rounded off drain plug #1,813
Post #36 shows the plug as well as a boss plate larger than plug, large enough to drill/tap either side of it.
Possibly another plate somewhere as well since picture only shows plug.
You could grind old plug flat, paint over it...out of site out of mind if you wanted.
He even mentioned the bar there "is easily removable" so plenty of room to work.
A two hour max job.
/ Rounded off drain plug #1,814
/ Rounded off drain plug #1,815
Kando will get it done. He simply has other life priorities. He just has more patience than most of us, and a better sense of humor than some of us,
/ Rounded off drain plug #1,816
Perhaps he is out visiting his brother, Sparc? :)
/ Rounded off drain plug #1,817
/ Rounded off drain plug #1,819
Me... I'd remove that bar that's in the way.
Grind the old plug even with plate. Center punch it. Drill stepping up in size. After draining I may try drill, tapping it same size...but probably next size larger.
This may have been suggested before.
/ Rounded off drain plug #1,820
If he had removed the bar in the first place this thread would have died a year ago... and he would probably be changing the fluid again.
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
International 9200 (A61307)
International 9200...
2012 Honda Civic Sedan (A59231)
2012 Honda Civic...
TEST YOUR BID BUTTON! (A62130)
TEST YOUR BID...
