Rounded off drain plug
/ Rounded off drain plug #1,801
You're preaching to the choir...but not necessarily to the sophomoric (bed wetters) denizens of this thread...
You've not missed anything as long as you read significant posts up to where the pictures are attached...then it's just a bunch of rhetorical advise that is primarily spot on and then a bunch of off the wall useless suggestions (some of them dangerous) that are just plain stupid...The reason the thread is so long is there is a contingent of goofs that have made stupid jokes and references throughout...Methinks "the goofs" are intrigued by the fact that they themselves have been able to remove a drain plug (on their own) that they are just giddy...
Piney, have you not heard of Depends for adults?
They will keep you from waking up in a warm puddle!
/ Rounded off drain plug #1,802
I've never ever broken a quality pipe wrench even using a long pipe cheater bar. Today I removed a very tight plug with a small wrench which gives a better bite.
The plug came out fine, except I had a whoopsy afterwards. 20190527_224013.jpg
/ Rounded off drain plug #1,803
Piney does have a fascination for peeing, that much is obvious.
/ Rounded off drain plug #1,805
LMAO...Seems I have a talent for striking nerves...along with the power to elicit confessions from goofs that are in the habit of taking naps after they amuse themselves in a carnal nature...LoL...!
Kando...ignore the clowns...they're not even funny when they embarrass themselves...
/ Rounded off drain plug #1,807
Well at least piney refrained from talking about urinating this time. That is good news. I am guessing he is back to choking chickens? Two theme Piney.
/ Rounded off drain plug #1,808
Actually, kidding aside, in any of the now almost 2,000 posts has anyone suggested THIS? Which is forget getting that plug out.
It's stuck tight! However (drum roll please), pick out a spot close by...and drill/tap a new hole!!!!!
Better location...away from that bar in the way. Start small, then working up to the correct tap size...then let it drain!!!!!
Next day tap it! No mess, fluid is gone.
I'd tap it slowly, removing chips.
Then pour kerosene or other cleaner through. New tap.
Fat lady sings, curtain closes.
FINI
/ Rounded off drain plug #1,809
Unless there is a good boss somewhere proper, drilling and tapping a new drain hole could be problematic
/ Rounded off drain plug #1,810
I don't recall; and am not inclined to search 1800 posts. Does anyone recall if Kando or others mentioned what the sump material is? Sheet material or cast? Totally different approach. Are we back on track?
Ron
KJ K4525 45'x25' Double Garage Barn Shed (A60463)
KJ K4525 45'x25'...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
