Round Pen for Horses
   / Round Pen for Horses #1
BeezFun
IL
Kubota B2710
I setup an 80' round pen, used 5' high, 12' wide panels that I bought at Farm and Fleet. I've had a problem with the panels either wanting to tip in toward the center of the round pen, or tip out away from the center, creating a sort of domino affect where it affects a lot of panels on each side. The panels are connected to each other with chains top and bottom. The whole thing seems less stable than I would have imagined. Anyone have any experience with these things, maybe it's just how they are.
   / Round Pen for Horses #2
The panels we use for our roundpen are held together with drop in pins. I can see where using chains to hold the panels together would allow what you are describing to happen.
   / Round Pen for Horses #3
If this is gonna be a semi-permanent place for round panel(pen) I would put steel round post in between each panel with wire or round wooden fence type post in ground. That would eliminate a lot of future trouble.Would also protect your investment in panels.
Boone
Boone
Thought about that. Neighbor had a suggestion to use those clamps they use for chainlink fencing to hold posts together, that might make it rigid enough.
We have pretty uneven ground, I didn't think pins would work if the panels don't come together plumb. That's why I got the style with chains.
   / Round Pen for Horses #6
The drop pins still work decently with uneven ground. It's it steep hills then flat, probably not.
I have a 100' round pen and still get some tilt, mine is the drop pin. And it's on even ground. I think once you get above the standard 60' size the panels don't balance as well due to the wider circle/less arc.
Rebar or similar pounded in every 3-4 panels is a big help, but not sure the best method for attaching a chain panel.
   / Round Pen for Horses #7
If the vertical pipe is open on the bottom of your panels, you can drive metal t-posts into the ground and drop the panel down onto the post. But, I think the idea of the post sandwiched between the chained panels as suggested should be relatively safe and help stabilize the panels.
I have had panels that chain together, panels that bolt together (the worst) and panels with pins that drop in. The drop pin type get my vote as the easiest to work with.
   / Round Pen for Horses #8
If not too late, return them and go get some fence posts and privacy panels. You really want to focus the horses attention on you and the training. The privacy panels will help them focus by lessening visible outside distractions (other horses, people, etc.)
   / Round Pen for Horses #9
I have been considering building a round pen that matches my wooden 3-rail fence. I'm interested in this "privacy panel" info, but I want to be able to see into and out of the pen myself for security and other reasons.
Very interesting...
Be well,
David
   / Round Pen for Horses #10
Our round yard uses drop in pins and it is very stable. Being on slightly uneven ground wouldn't affect it.
2019 Dodge Durango (A53421)
2019 Dodge Durango...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
24ft T/A Enclosed Cargo Trailer (A53424)
24ft T/A Enclosed...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
