Grading Rotating rear blade questions
/ Rotating rear blade questions #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
I read a review the other day of the TSC Countryline rear blade and got to wondering...
Do most mfg make the rear blade so you can rotate it without unhooking? I assumed - and you know where that gets you - that all rear blades could be rotated 360 degrees without having to unhook them..
I wasnt sure how to even search for this topic - sorry if it has been covered before
Brian
/ Rotating rear blade questions #2
Most will rotate, but it depends on your tractor and the length of the blade.
Usually, if you lift it just above the ground, it will clear the tires.
I can rotate a 7 ft blade on my MF 175
/ Rotating rear blade questions #3
I have a BX2350 with a 5' blade and I can rotate it all the way around. I never thought about it much, but I suppose if it was longer, it wouldn't clear. I would say they are all designed to be rotated without unhooking it, but if I put something like a 7' blade on my tractor, I'm sure it would hit.
/ Rotating rear blade questions #4
For a data point:
My 6' rear blade rotates OK, my 7' landscape rake hits the tires. On a Kubota7800
/ Rotating rear blade questions #5
IMHO, any rear blade should be designed to miss the tractor/tires when rotated. That is just part of a good design. I wouldn't buy one that could not swing in a complete arc. That is why wider blades sit back farther that narrow ones. I frequently swing my blade around for back blading and smoothing or if pushing snow backwards.
/ Rotating rear blade questions #6
The length you have your top link set at can also make a difference.
thanks for the feedback.. The review I read said that the blade would not rotate - and it looks like the exception - OR the reviewer didnt have it in the right position to rotate.
I thought they should, but was just curious
brian
2014 Kawasaki 70Z7 Articulated Wheel Loader (A64553)
2014 Kawasaki 70Z7...
2022 EZ-GO ELITE...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
2011 Kenworth T300 S/A 18ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
