Rotating operators position
/ Rotating operators position #2
Thanks, that is amazingly easy; sure couldn't figure it out, very impressive engineering.
/ Rotating operators position #3
Wow, are the shifters backwards then. It didn't look like they moved? Does that confuse you a little or do you get used to it. That sure would be handy for some things.
I've heard about problems with pushing with a threepoint. Does this tractor have a special threepoint or do you just have to be careful?
Cool tractor, Electrarc.:thumbsup:
Tucker,
Yes the shifters are backwards but they are clearly labelled and so easy to use. The steering left/right changes automatically. The three point is a quick connect, but it pushes a standard brush hog no problem. A post hole digger is just so easy to use even on a slope.
Cheers
/ Rotating operators position #5
Tucker,
Cheers
That looks like it would be much easier to use a post hole digger in that machine than a regular tractor. No crook in the neck afterwards.:thumbsup:
Take care
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
