Rotating operators position
/ Rotating operators position #2
Thanks, that is amazingly easy; sure couldn't figure it out, very impressive engineering.
/ Rotating operators position #3
Wow, are the shifters backwards then. It didn't look like they moved? Does that confuse you a little or do you get used to it. That sure would be handy for some things.
I've heard about problems with pushing with a threepoint. Does this tractor have a special threepoint or do you just have to be careful?
Cool tractor, Electrarc.:thumbsup:
Tucker,
Yes the shifters are backwards but they are clearly labelled and so easy to use. The steering left/right changes automatically. The three point is a quick connect, but it pushes a standard brush hog no problem. A post hole digger is just so easy to use even on a slope.
Cheers
/ Rotating operators position #5
Tucker,
Cheers
That looks like it would be much easier to use a post hole digger in that machine than a regular tractor. No crook in the neck afterwards.:thumbsup:
Take care
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A59911)
2005...
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
