Rotating operators position
/ Rotating operators position #2
Thanks, that is amazingly easy; sure couldn't figure it out, very impressive engineering.
/ Rotating operators position #3
Wow, are the shifters backwards then. It didn't look like they moved? Does that confuse you a little or do you get used to it. That sure would be handy for some things.
I've heard about problems with pushing with a threepoint. Does this tractor have a special threepoint or do you just have to be careful?
Cool tractor, Electrarc.:thumbsup:
Tucker,
Yes the shifters are backwards but they are clearly labelled and so easy to use. The steering left/right changes automatically. The three point is a quick connect, but it pushes a standard brush hog no problem. A post hole digger is just so easy to use even on a slope.
Cheers
/ Rotating operators position #5
Tucker,
Cheers
That looks like it would be much easier to use a post hole digger in that machine than a regular tractor. No crook in the neck afterwards.:thumbsup:
Take care
John Deere 1025R (A62177)
John Deere 1025R...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2020 FREIGHTLINER...
