Rotating operators position
/ Rotating operators position #2
Thanks, that is amazingly easy; sure couldn't figure it out, very impressive engineering.
/ Rotating operators position #3
Wow, are the shifters backwards then. It didn't look like they moved? Does that confuse you a little or do you get used to it. That sure would be handy for some things.
I've heard about problems with pushing with a threepoint. Does this tractor have a special threepoint or do you just have to be careful?
Cool tractor, Electrarc.:thumbsup:
Tucker,
Yes the shifters are backwards but they are clearly labelled and so easy to use. The steering left/right changes automatically. The three point is a quick connect, but it pushes a standard brush hog no problem. A post hole digger is just so easy to use even on a slope.
Cheers
/ Rotating operators position #5
Tucker,
Cheers
That looks like it would be much easier to use a post hole digger in that machine than a regular tractor. No crook in the neck afterwards.:thumbsup:
Take care
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
Case skid steer wheels and tires (A63689)
Case skid steer...
2007 Genie AWP-30S 30ft Manlift (A61572)
2007 Genie AWP-30S...
Mini Bucket Excavator Attachment (A61572)
Mini Bucket...
iDrive TDS-2010H...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
