Rotating operators position
/ Rotating operators position #2
Thanks, that is amazingly easy; sure couldn't figure it out, very impressive engineering.
/ Rotating operators position #3
Wow, are the shifters backwards then. It didn't look like they moved? Does that confuse you a little or do you get used to it. That sure would be handy for some things.
I've heard about problems with pushing with a threepoint. Does this tractor have a special threepoint or do you just have to be careful?
Cool tractor, Electrarc.:thumbsup:
Tucker,
Yes the shifters are backwards but they are clearly labelled and so easy to use. The steering left/right changes automatically. The three point is a quick connect, but it pushes a standard brush hog no problem. A post hole digger is just so easy to use even on a slope.
Cheers
/ Rotating operators position #5
Tucker,
Cheers
That looks like it would be much easier to use a post hole digger in that machine than a regular tractor. No crook in the neck afterwards.:thumbsup:
Take care
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
CASE INTERNATIONAL 2208 - 8R30" CORN HEAD (A63291)
CASE INTERNATIONAL...
