Rotating operators position
   / Rotating operators position #2
Thanks, that is amazingly easy; sure couldn't figure it out, very impressive engineering.
   / Rotating operators position #3
Wow, are the shifters backwards then. It didn't look like they moved? Does that confuse you a little or do you get used to it. That sure would be handy for some things.
I've heard about problems with pushing with a threepoint. Does this tractor have a special threepoint or do you just have to be careful?
Cool tractor, Electrarc.:thumbsup:
Tucker,
Yes the shifters are backwards but they are clearly labelled and so easy to use. The steering left/right changes automatically. The three point is a quick connect, but it pushes a standard brush hog no problem. A post hole digger is just so easy to use even on a slope.
Cheers
   / Rotating operators position #5
Tucker,
Cheers
That looks like it would be much easier to use a post hole digger in that machine than a regular tractor. No crook in the neck afterwards.:thumbsup:
Take care
2019 Allmand Bros Maxi-Lite 2V 15W S/A Towable Light Tower (A52377)
2019 Allmand Bros...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A53843)
RAKE ATTACHMENT...
2019 PETERBILT 579 TANDEM AXLE SLEEPER TRUCK (A54607)
2019 PETERBILT 579...
2020 KUBOTA RTV...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
