Highbeam
Super Member
Highbeam: >>brush hog is a tool of mass destruction<<
LOL. With a description like that, I simply MUST have one.
-------It is a cool machine. You can back it up and over piles of rubbish or old rotten stumps and then lower the blades into them and shred the junk up into little pieces. There's much more to a brush hog than just setting the height and dirving forward in rows. It'll do that too though.
Highbeam: >>The finish mower uses rigid lawn mower type blades while the brush hog uses a pair of 1/2" thick by 4" wide blades that are hinged near the dirve axle.<<
So if I look underneath the machine I am considering and it has a blade that looks like my MMM's, it is a finishing mower? Rougher cut mowers will have the hinged blades? I don't want for the dealer to sell me a "bill of goods" so, excuse my ignorance. I want to make sure what I buy will do what I want.
-------Yes, the blades will be very substantial and are hinged so that if you drive over a huge stump the blades could bounce around the stump while the pto keeps spinning. This provides a weed wacker effect with each wack being given by a huge chunk of steel.
I always wondered how cool it would be to remove a piece of the rear end of the shroud so I could back the blades right into trees. Basicly exposing the blades to full tress just like a weed wacker string is exposed to grass blades. Probably very dangerous.
350 lbs sounds pretty light. My 30 HP tractor lifts nearly a ton. Close to 1750 as I recall at the 3ph.
