Rotary Cutter Rotary Cutter
/ Rotary Cutter #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I have an overgrown field edge I want to hog some paths into. Mostly woody brush up to 1 inch or so diameter, up to 2 feet tall. I was thinking of backing into the stuff from the open field with the RC lifted a foot or so, tail wheel off the ground. Then going forward over the same path with cutter lowered to 8 inches or so. That would allow me to check better for rocks and stumps after cutting with higher setting before lowering deck. Any thoughts??
/ Rotary Cutter #2
I cut that stuff all the time. Going backward is a PITA!~ I just lower the FEL to about 2-3" off the deck and go forward. Keep your hand on the 3pt lift lever and give a yank when it smacks something. No big deal, that's what they are made for.
jb
/ Rotary Cutter #3
Ditto what JB said.. I hate mowing with my mower up... lets all kinds of debri fly.
While I have backed into some areas and mowed backwards.. I usually just choose a slow gear and go forward and le tthe tractor front axle lay it all over.. Keep an eye out.. if you see a rock, stump.. car tire.. get onthe clutch and the lift.. etc..
soundguy
/ Rotary Cutter #4
Same advise as these guys gave you. Be more concerned about your tractor tires getting trashed. The cutter can hit all manner of things and keep on going.
/ Rotary Cutter #5
*Any thoughts??
*YEAH !
Sounds dangerous.
Hard tellin what that thing might throw into you and tear you up with it.
L . B .
Landhonor Diesel Heater (A66408)
Landhonor Diesel...
2021 Kawasaki Teryx KRX 1000 SE (A62679)
2021 Kawasaki...
Rolling Cart (A65640)
2022 EZ-GO ELITE...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
