Buying Advice Rotar tiller
/ Rotar tiller #1
Adam2012
Landtrac 360dts 2000
I am thinking about buying a rotar tiller to go behind my tractor. My tractor is a landtrac 360. Does anyone have any advice what brand, size any other info?
/ Rotar tiller #2
I think your tractor is around 35 hp at the pto, which should enable you to get a tiller in the 60-80 inch range and still have lots of power. As far as manufacturer there are lots out there. I got mine off CL and it's an ortolan s series.
/ Rotar tiller #3
I am going to play the banker role.
What do you plan to do with the tiller?
Some of the members might see a different solution to your inqury.
Craig Clayton
/ Rotar tiller
I just plan on tilling my garden with it about half of a acre.
/ Rotar tiller #5
Get yourself a King Kutter tiller, and you are all set.
I like my tiller to cover both tire tracks, but you can use an offset tiller if you don't mind the aggravation.
Generac Generator (A61572)
Generac Generator...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
1058 (A63291)
1058 (A63291)
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
