ROPS for 2210D
/ ROPS for 2210D #1
vongiese
NW Montana
Yanmar 2210D, Sany SY35 Excavator, Kubota 4060LE,
I'm going to have a ROPS made for my 2210D. I was wondering if any of you could post some good pictures and or diagrams of ROPS for similar tractors so I can show the guy whos gonna fabricate one for me.
Maybe it wouldbe best to buy the mounting brackets from Yanmar and have the rest made?
Any help would be appreciated!!
/ ROPS for 2210D #2
Vongiese:
If your still looking for pic's of ROPS for smaller tractors I can take pic's of mine for a YM187 over the weekend and slap a tape to it so you have some numbers to go by, but I have no Idea if what I have would even come close to fitting yours.
Whiskey
/ ROPS for 2210D
Thanks for the offer Whiskey - anything would help get some ideas going. i found a few pics doing a thorough search too.
mike
/ ROPS for 2210D #4
Here is what is on mine. Image attached
/ ROPS for 2210D #5
I recently modified a Ford ROPS to fit my 2010D.
I solved the mounting of the ROPS to the rear axle by cutting off the fender mounts to the axle. This provided room for the ROPS mounting.
The Ford had a "C" shaped bracket with two grade 8 bolts which gripped the axle. From that "C" shaped bracket, a rectangular vertical support extended inside the fender, to the underside of top of the fender.
This support has a flat plate on the top surface with four 1/2" holes. Now the ROPS can be bolted on the top of the vertical support with the fender sandwiched between.
I am going to add additional support by fabricating square tubular supports from the front loader mounts to the rear axle. These supports will provide a surface to mount triangle shpaed supports inside the fender. See my post titled Modifications to Yanmar 2010D
I will post additional photos as soon as I do some more fabrication.
Thanks,
Cameron
/ ROPS for 2210D #6
Cameron, I dont want to bother you but can you measure the width of the ROPS where it attaches to the fender? I'm in need of an ROPS also and don't really need those fender mounts on the axle. I'd feel a lot better about it if I had a little protection. My tractor is a FF205D Yanmar. I'm hoping it is roughly the same size as your 2010D.
thanks for any help, Brett Widenhouse
/ ROPS for 2210D #7
Sorry for the slow reply. The Ford ROPS where it mounts to the top of the fender is 40" OD and 31" ID. My YM2010D was +/- 1" wider and I needed to slightly narrow the fenders a bit. Not very hard. I just shimmed them out with some longer machine screws and the rubber mounts from under the fenders. Now it fits perfectly and no rattles. The fenders are securely fastened to the ROPS and they feel more solid than stock.
Cameron
/ ROPS for 2210D #8
Cameron, thanks,
Is your ROPS 4.5 inches wide? So OD is 40, ID is 31,
40-31= 9 divided by 2. thanks again, I'll go and measure my machine, I know it is 48 wide OD on the treads. brettw
/ ROPS for 2210D #9
Cameron,
One more question is you don't mind, Is there any special number or designation on that Ford ROPS? Or are they all the same. thanks agian, Brett W
Looks like the best way for me to get an ROPS.
/ ROPS for 2210D #10
Hey Brett, if that works let me know, I might be able to do the same to my 1810. /forums/images/graemlins/smirk.gif
/ ROPS for 2210D #11
Attached is a photo of the plate on the ROPS. I has all of the information that I have. The serial number not visible on the plate is: 02686
Cameron
/ ROPS for 2210D #12
The plates are 4-5/16" wide by 6" long
/ ROPS for 2210D #13
If you guys are considering using Ford ROPS, drop me an email and I will give you some specific tips on things that I learned along the way.
Thanks,
Cameron
/ ROPS for 2210D #14
Cameron, thanks again. This looks doable to me. bw, I'll go out and measure my tractor now for width. Will email you if I get to the next step and buy a Ford ROPS. bw
/ ROPS for 2210D #15
Vongiese:
Sorry for taking so long to get the pic's in here forgot all about the thread untill it poped to the top again so if ya still wanta see here they are and you are still needing numbers to go by I can get that for you too.
Whiskey
/ ROPS for 2210D #16
pic 2
/ ROPS for 2210D #17
pic 3
/ ROPS for 2210D #18
pic 4
/ ROPS for 2210D
Thanks for posting those photos Whiskey. WHat is the width at the bottom and at the widest? And would you mind posting the height?
/forums/images/graemlins/grin.gifthanks!!
/ ROPS for 2210D #20
Vongiese:
I get in late tonight, so if I can't get them tonight I'll be sure to get them on Thursday.
Whiskey
2018 Volvo VNL Truck, VIN # 4V4NC9EH0JN894705 (A61568)
2018 Volvo VNL...
2020 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TANK MANIFOLD (A60736)
(12) SKLP SK-LJB-12 Polyethylene Roadbed Protection Pads (A60463)
(12) SKLP...
43024 (A59228)
43024 (A59228)
