Root Rake Build
/ Root Rake Build #1
massey240
Greenville, sc
Massey 240
Small 5 foot root rake I built for my New Holland TC30. We have 20 acers that we are cutting atv trails in with small trees from 1 inch up to about 4 inches. I left bar stock out of center so I can push small trees over then grab roots and push. I have about $75 bucks in everything all the metal was from scrap yard. Built in about 8 hours with a mig welder, metal chop saw and plasma cutter. Weight is 300 to 350 lbs. What do you all think?
/ Root Rake Build
Here are the brackets I built to hook it onto the loader. Next project is going to be building a quick attach system for the loader so I can run skid steer attachments.
/ Root Rake Build #3
Nice project with good build quality. If you added #9 mesh to the top section why not add it to the lower section? Let us know how it works for you in the brush and trees.:thumbsup:
/ Root Rake Build
I added the mesh to the top to protect from limbs getting my hydraulic cylinders and hoses. If I have problems with limbs on bottom I may add mesh. I want as much dirt as possible to go threw the tines. One area I expect I may have to add some protection is there the lift arms connect I'm afraid limbs may get caught up in that area, only time will tell if I need to add 1/4 plate there for protection. Thanks for the comments!
/ Root Rake Build
Here it is set up on my TC30. Plan to use it to clean ATV trails. I also just bought another six acers with tons of little trees 1-2 inches in diameter. I will bush hog them then run rake over it and clean roots and put in food plots.
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
Caterpillar 988B Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 988B...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
Caterpillar 966F Series 1 and 2 Wheel Loader Service Manuals (A63117)
Caterpillar 966F...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
