Root Rake Build
/ Root Rake Build #1
massey240
Greenville, sc
Massey 240
Small 5 foot root rake I built for my New Holland TC30. We have 20 acers that we are cutting atv trails in with small trees from 1 inch up to about 4 inches. I left bar stock out of center so I can push small trees over then grab roots and push. I have about $75 bucks in everything all the metal was from scrap yard. Built in about 8 hours with a mig welder, metal chop saw and plasma cutter. Weight is 300 to 350 lbs. What do you all think?
/ Root Rake Build
Here are the brackets I built to hook it onto the loader. Next project is going to be building a quick attach system for the loader so I can run skid steer attachments.
/ Root Rake Build #3
Nice project with good build quality. If you added #9 mesh to the top section why not add it to the lower section? Let us know how it works for you in the brush and trees.:thumbsup:
/ Root Rake Build
I added the mesh to the top to protect from limbs getting my hydraulic cylinders and hoses. If I have problems with limbs on bottom I may add mesh. I want as much dirt as possible to go threw the tines. One area I expect I may have to add some protection is there the lift arms connect I'm afraid limbs may get caught up in that area, only time will tell if I need to add 1/4 plate there for protection. Thanks for the comments!
/ Root Rake Build
Here it is set up on my TC30. Plan to use it to clean ATV trails. I also just bought another six acers with tons of little trees 1-2 inches in diameter. I will bush hog them then run rake over it and clean roots and put in food plots.
2013 Ford F-150 Ext. Cab Pickup Truck (A61573)
2013 Ford F-150...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
2016 Freightliner M2 106 Ambulance (A61573)
2016 Freightliner...
Caterpillar Blade Control Service Manuals (A63117)
Caterpillar Blade...
LOOK! (A63109)
LOOK! (A63109)
2014 Hyundai VI2530112 53ft. T/A Dry Van Trailer (A61573)
2014 Hyundai...
