Roof Beam replacement.
/ Roof Beam replacement. #62
Every time you modify something, or remove part of a structure, you cause damage to what's remaining. It takes a lot more figuring out of things to know what you will end up with after the modification, then it does to do the modification. None of us know what is going on with that truss enough to suggest making any changes to it. Assuming that there is a ridge beam that can support rafters if the truss is modified isn't something I'm on board with, or willing to encourage.
Fix what's broken, make it stronger then before, and add more to it, but never do anything that makes it weaker.
  • Good Post
Reactions: JJT
/ Roof Beam replacement. #63
This thing has already broken once and several people have already had expressed different opinions on how to make the repair and whether the truss should have been designed and built this way. That's not a good situation to step into for someone trying to make a repair.
I'm just hoping it is now stable enough that a snow load this winter won't break it.
/ Roof Beam replacement. #64
But we do know what's going on with it, or at least those of us who are intimately familiar with that style and dimensions of construction do. 30-40 ft. wide post frame buildings are ubiquitous in the OP's area. I live in one, in fact, as do many of my neighbors. I also build them, regularly, using the same methods I've been describing. The design and methods to build them are very well known and understanding the forces involved is not complicated once you've worked on, repaired and built enough of them.
/ Roof Beam replacement. #66
I'm a contractor and I get a lot of work fixing what others have done wrong. Usually it's removing something that they where positive didn't need to be there. Only thing worse then somebody modifying something, is telling others to modify it without actually have hands and eyes on it.
/ Roof Beam replacement. #68
If you take out the bottom chord, you are dramatically changing the stress on the members and their connections. the original failure was at connection and your recommendation is increasing stress in those connections
Not with a post holding up the center it isn't.
have you ever heard of the collapse of the balcony at the Kansas City Hyatt. Similar setup killed over 100 people when balcony collapsed
/ Roof Beam replacement. #69
Same here. I deal with other people's poor workmanship quite regularly. In that, it sound like we're similar. One, (perhaps significant, perhaps not) difference though, is that I'm a contractor in the region where the OP is located, who specializes in the type, style of construction and general size of building that we're discussing.
I hadn't heard of that. I'll look it up. How many balconies of the exact same dimensions had the person who removed the supports built or modified before? Were there hundreds of balconies of the same size and construction style, dealing with the same loads in the area to compare it to?
/ Roof Beam replacement. #70
I wouldn't remove the bottom chord, because even with the left side of the (bottom) chord broken, there was still some tension functionality served with the rest of the truss - particularly once the bottom was braced:
Yes, putting in a ridge-to-floor support probably obviates the chord. Probably.
The only thing I'd consider is putting in a few extra studs in that wall right under the king post and remove the tree trunk replacement and regain that few inches.
Otherwise I wouldn't take it any further than he's already got it... but I do look forward to the next 10 pages of this thread now that the op's done ;)
/ Roof Beam replacement. #71
In case it wasn't clear, I wasn't suggesting that the bottom cord could be removed with things as they are now. I was suggesting it could be done if there was a single, floor to ridge post, as you mention. But, as I said before, I think he's fine with things as they are now (at that truss).
/ Roof Beam replacement. #72
I have heard of it and studied it. There is little similarity other than a faulty design although it is not clear that the truss actually even had an engineered design.
BTW, the Hyatt event involved elevated walkways, not balconies.
/ Roof Beam replacement. #73
Fabricator Modified design which greatly increases stress In member. Member failed due to increase stress
/ Roof Beam replacement. #74
For the truss in this thread there is little evidence of the fabricator modifying its design or that an original design ever existed. It may have been just constructed.
/ Roof Beam replacement. #75
The truss in question here didn't have a "designer" per se, other than whoever built that building. That's clearly not a commercially made, engineered truss. The member failed because of the "design", not because the design was modified.
/ Roof Beam replacement. #76
some people are recommending changing the truss by removing lower chord. Making center column in two pieces drastically increases stress in the joints
/ Roof Beam replacement. #77
I didn't see anyone suggest a two piece center column.
/ Roof Beam replacement. #79
Lots of people think they know how things work - but really don't. A number of years ago I read a lengthy piece in a farming publication my FIL subscribed to. There was a big story on building collapses during a larger snowstorm. Most were caused by owners doing mods to their buildings after the buildings were completed by the contractors.
One of the main problems was making attachments to the bottom chords of trusses for walls or stall dividers. Some were homebrew "supports" that owners added. When solid attachments were made, it changed the dynamics of the stresses and didn't allow for the truss to flex as it should. The "support" created a failure point.
They had pictures of good and bad connections. The bad ones created a solid connection between the floor and the truss. The good connections were made solid to the floor and went past the bottom of the truss, going through a guide so the truss could slide up or down.
IIRC, the Hyatt tragedy was caused by the failure of the anchors. Someone decided the ceiling rod supports were unsightly and eliminated some?
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2018 KOMATSU WA200-8 WHEEL LOADER (A60429)
2018 KOMATSU...
UNUSED FUTURE 30" MINI EXCAVATOR PALLET FORKS (A60432)
UNUSED FUTURE 30"...
2006 Freightliner M2 106 T/A Dump Truck (A59230)
2006 Freightliner...
