Robbin 22hp Engine
/ Robbin 22hp Engine #11
I know nothing about the PT's but I would think that they would come up with an electric clutch to keep from having to spin the cold oil with the starter. Are they set up direct drive off of the engine?
/ Robbin 22hp Engine #12
Saddly PT is a great machine but is not known for forward thinking or customer suggestions for improvement. It is a dirt simple machine...
/ Robbin 22hp Engine #13
Here's a link to a video of me plowing snow last Feb. Last February was the coldest February temp on record with an average of 10F for the first half of the month and it was also the second most February with days below zero temp with 7 days below 0.
/ Robbin 22hp Engine #14
Yes... three pumps on mine.
And that, MossRoad, is what I am talking about!
It is a tractor, right? It is not a high dollar sport car that you might understand that you need to baby it, and have a master mechanic to give it deep body message!
Why shouldn't mine run (especially start) like MossRoad's?
Mine is even two years newer.
We live in the same climate zone.
But! And here is a "Big Momma butt"...his is a "kohler"!
Mine is a stinking (odor) stubborn (cold start) "Robin".
There lies the problem.
/ Robbin 22hp Engine #16
And then you have the other guy that doesn't like Kohler. What is there not to like about a Kohler. It is a fine engine.
/ Robbin 22hp Engine #17
To continue the thread of it is reasonable to expect the engine to start at colder temperatures...
MR is certainly helping out cold cranking by keeping the battery absolutely full. Even (especially?) for my diesel truck, I now keep a pair of solar chargers on it always. This means it now starts in seconds every time, whereas before sometimes you would have to crank for minutes after the glow plugs were warm. It was true for new or older batteries alike. Having the battery absolutely full can make a noticeable difference in starting power.
Idabe: A low battery won't affect your spark, but since you have two independent coils, and the engine runs OK, I don't think anything is wrong with the sparking part of your engine. (Unless your storage area is really damp.) A full battery will crank the engine at higher speed, which means the combustion gases get warmer, which increases the chance that they will ignite.
Idabe, I think you are right to be dissatisfied with the performance of the engine, but I also of the opinion that it should be fixable. (trickle charger, better tuning, float valve, etc.) Given all of your comments, I'd have a go at the carb first. I do know that they have changed the starter motor on these engines to a Hitachi; I have no idea if it works any better.
By the way, if you have an old wall wart, a number of the older ones put out 12-14VDC and can be used for trickle charging for the cost of adding battery clamps, or hook up wires. I have one from an old printer that puts out 14.5V @500mAuntil you load it with a battery, when it happily puts out 12.8V, rising to about 13.2V when it finishes charging. I use one to charge my trailer batteries up periodically.
All the best,
Peter
MossRoad said:
I have a 2001 Model year PT425 with the Kohler Command engine. I have never pre-heated it. I have started down below -10F (-23C) a few times each winter. At those temps, the cold hydraulics really put a load on the engine starter and you can hear it and feel it dragging until it starts, which is usually under 5 seconds of cranking. The only thing I do is keep a 500MW charger on the battery all the time in winter. The original battery lasted 5 years. I sometimes let it sit for weeks at a time in the winter.
/ Robbin 22hp Engine #18
ponytug said:
My coworker has a great line:
Q "What is the definition of insanity?"
A "Doing the same thing over and over, and expecting a different result..."
Sounds like somebody who works on computers. I mean the crazy part.
/ Robbin 22hp Engine #19
It came up in a different context, and he would not describe himself as skilled in technology. He's more of a turn it on and use it kind of guy...
/ Robbin 22hp Engine #20
The first 3-4 years I never used the trickle charger. I used it after some discussion here regarding prolonging battery life, not hard starting.
The Robin should start right up. From everything I have read they are dependable engines. However, this cold starting issue has been reported many times here.
So, do they crank with the starter O.K. but just never fire up or do they have trouble cranking, too?
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
iDrive TDS-2010H...
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
