Roaring L-1500
/ Roaring L-1500 #1
jcline
Northeast Alabama
kubota L1500
My little 1500 Kubota has developed a loud roaring type sound when the pto is engaged with the cutter hooked up,it does not make this sound when engaged without an attachment.Has anyone else ever experienced this or have a suggestion as to what it may be going or gone bad?It runs and pulls great other than that.I hate to just start buying parts and experimenting if someone may have an idea on what is causing this.
/ Roaring L-1500 #2
Hook the cutter up to another tractor, if the noise follows the cutter,,,,,,,,ya know.
/ Roaring L-1500 #3
Have you looked under the cutter to see if something has wound itself around the blades?:confused:
/ Roaring L-1500
Yea,I have checked the cutter out and its fine and runs like it should behind another tractor,since this post I have even developed the same sound from all the low speed gears but still quiet when running in a high gear.this is without using the pto just while running !Beats me ,I am starting to fear that I may have some serious gear problems somewhere in there but its strange that its happening all the sudden like it is.
/ Roaring L-1500 #5
Have you drained the trans/diff oil to check for debris? Sounds like a bearing gone.
2019 CATERPILLAR CUV82 UTV (A64280)
2019 CATERPILLAR...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2022 Chevrolet...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A61573)
2013 International...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
