Ripper
/ Ripper #41
Ouch, I see the attachment is bent, but are the lower 3pt arms bent in that pic as well? What did you hook?
/ Ripper
The 3 pt. is fine.
I didn't hook anything. It just gradually bent into that shape as I was ripping some old weedy pasture to till and re-plant. Sod can be VERY tough.
/ Ripper #43
I have no experience with the 3pt. Looking at it, Im amazed it can take much strain, maybe a steady pull but running a ripper into anything fairly hard, and fairly quick I could see the pins attaching the 3pt lower arms to the tractor breaking or something. But I dont hear much damage from them. I'm amazed. I would probably build one strong enough that the cross member between the two lower arms would hold for sure.
/ Ripper
The tabs that the 3 point arms connect to are plenty heafty. The only 3 pt. damage I hear of is the ears for the top link breaking. The only time I've heard of that is when there's a combination of a 3 pt. backhoe and some pretty heavy over use (abuse).
/ Ripper #45
Yeah it amazes me. How about people pushing backwards with a blade.
/ Ripper
Rumor has it that it's not good for a tractor, but I've never heard or even read a first hand account of it happening. I find that when I push backward, the blade tends to lift more, and I don't get the ground engagement like I want. It's as if going backward creates even less force on the arms for me.
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
John Deere 1025R (A53317)
John Deere 1025R...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
DEUTZ MARATHON...
