Ripper
/ Ripper #41
Ouch, I see the attachment is bent, but are the lower 3pt arms bent in that pic as well? What did you hook?
/ Ripper
The 3 pt. is fine.
I didn't hook anything. It just gradually bent into that shape as I was ripping some old weedy pasture to till and re-plant. Sod can be VERY tough.
/ Ripper #43
I have no experience with the 3pt. Looking at it, Im amazed it can take much strain, maybe a steady pull but running a ripper into anything fairly hard, and fairly quick I could see the pins attaching the 3pt lower arms to the tractor breaking or something. But I dont hear much damage from them. I'm amazed. I would probably build one strong enough that the cross member between the two lower arms would hold for sure.
/ Ripper
The tabs that the 3 point arms connect to are plenty heafty. The only 3 pt. damage I hear of is the ears for the top link breaking. The only time I've heard of that is when there's a combination of a 3 pt. backhoe and some pretty heavy over use (abuse).
/ Ripper #45
Yeah it amazes me. How about people pushing backwards with a blade.
/ Ripper
Rumor has it that it's not good for a tractor, but I've never heard or even read a first hand account of it happening. I find that when I push backward, the blade tends to lift more, and I don't get the ground engagement like I want. It's as if going backward creates even less force on the arms for me.
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
RoGator and Terragator Manuals (A63117)
RoGator and...
Brake Drums (A62613)
