Ripper teeth
/ Ripper teeth #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Need to change a ripper tooth. They are dimpled on. Parts house guy said use a torch. When the dimpled area is red hot pry the old tooth off.
The slip the new tooth on, get it red hot and use a punch to dimple it on both sides.
Anybody have some sage wisdom to add to that?
/ Ripper teeth #2
Scooter, that is right, but since you have the torch, cut the old dimples out and knock off with a hammer.
New points heated at the dimples is great, but you can punch the dimples with punch cold too.
/ Ripper teeth
I don't have a torch. I have access to one. But initially I thought maybe just drill out the dimple with an oversized bit to remove the old tooth.
/ Ripper teeth #4
Saw a youtube vid where these points were changed. I think he used a cutoff wheel to remove them. Then he used a press to dimple the new ones on.
/ Ripper teeth #6
I have cut the teeth off with a angle grinder and cut off wheel. you might be able to drill the dimple out. As stated already a torch works too. Let us know what you do!
/ Ripper teeth
I went the drill route for removal. The dimple was smaller than the bit I used on purpose.
Once I drilled most of each side out I simply held the sock with the tooth hanging down and pinged it with a hammer a few times and it popped of. Then I used a 3/8 punch and hammer - but used a press on the other side after carefully marking the dimples on the tooth. It went okay. I would do it again, in fact I bought extras.
/ Ripper teeth #8
I think the punch divot is to sharp and to deep. But it is good enough for home owners use, especially since you don't have a torch. Good going! (y)
/ Ripper teeth #9
We used a 5 lb hammer on one side and a ball peen hammer
on the other
willy
/ Ripper teeth
Agreed. On the other side we used a press with the same punch and got a better looking dimple.
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
2019 HYDREMA 922F HM ARTICULATING DUMP TRUCK (A65053)
2019 HYDREMA 922F...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63689)
PENDING SELLER...
Drill Press (A64119)
