Ripper teeth
/ Ripper teeth #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
Need to change a ripper tooth. They are dimpled on. Parts house guy said use a torch. When the dimpled area is red hot pry the old tooth off.
The slip the new tooth on, get it red hot and use a punch to dimple it on both sides.
Anybody have some sage wisdom to add to that?
/ Ripper teeth #2
Scooter, that is right, but since you have the torch, cut the old dimples out and knock off with a hammer.
New points heated at the dimples is great, but you can punch the dimples with punch cold too.
/ Ripper teeth
I don't have a torch. I have access to one. But initially I thought maybe just drill out the dimple with an oversized bit to remove the old tooth.
/ Ripper teeth #4
Saw a youtube vid where these points were changed. I think he used a cutoff wheel to remove them. Then he used a press to dimple the new ones on.
/ Ripper teeth #6
I have cut the teeth off with a angle grinder and cut off wheel. you might be able to drill the dimple out. As stated already a torch works too. Let us know what you do!
/ Ripper teeth
I went the drill route for removal. The dimple was smaller than the bit I used on purpose.
Once I drilled most of each side out I simply held the sock with the tooth hanging down and pinged it with a hammer a few times and it popped of. Then I used a 3/8 punch and hammer - but used a press on the other side after carefully marking the dimples on the tooth. It went okay. I would do it again, in fact I bought extras.
/ Ripper teeth #8
I think the punch divot is to sharp and to deep. But it is good enough for home owners use, especially since you don't have a torch. Good going! (y)
/ Ripper teeth #9
We used a 5 lb hammer on one side and a ball peen hammer
on the other
willy
/ Ripper teeth
Agreed. On the other side we used a press with the same punch and got a better looking dimple.
