Ballast Rim Guard and punctures
/ Rim Guard and punctures #21
Using liquid ballast in tractor tires.
/ Rim Guard and punctures #22
In an ideal world the tires will be dry tubeless radials . With external cast weight bolted on for ballast . Contrary to what most folks think . There is lots of room for cast ballast on the inside and outside of the tire .
My owners manual states that you cannot use more than 2 55 pound weight per tire. And my loader requires 2300# of ballast. And if you have a backhoe that is only 1300# so were do you get the other 900#
/ Rim Guard and punctures #23
For a front loader the further behind the rear wheels ballast is the more effective it is vs wheel ballast. Calculated it for two tractors and it is 30 to 40% more effective. 1300 pounds sounds light for backhoe with a FEL needing 2300 pounds ballast.
/ Rim Guard and punctures #25
Just get a qualified employee to operate the tractor.
/ Rim Guard and punctures #26
Id probably try to curl up something up with the backhoe dipper stick and bucket for more counterweight, then use a ratchet strap to temporarily secure it.
/ Rim Guard and punctures #27
I can’t help but think liquid ballast works better than nothing, but the downsides of using it, as described above, are not a long term, reliable or practical method.
/ Rim Guard and punctures #28
Multiple manufactures quietly recommended only 40% liquid fill. They do this at a low level because they know their dealers are still filling at the 75% old standard.
For someone with 350 pounds liquid per tire this takes it down to 190 pounds.
/ Rim Guard and punctures #29
So what do they do with the tubeless Calcium Chloride fills. Supposedly it doesn't corrode the rims if the rims are completely submerged and can't interact with the air.
/ Rim Guard and punctures #30
Supposedly is a real big word,
I have seen a few of the rims which were run tubeless and filled over the top of the rim,
it still corroded quite badly
If this works it is a link to a pdf of the amount of calcium chloride per gallon of water and its slush and solid freeze points;
https://www2.gov.bc.ca/assets/gov/farming-natural-resources-and-industry/agriculture-and-seafood/farm-management/structures-and-mechanization/200-series/210104-1_calcium-water_table_for_tractor_tires.pdf
edited to add,
when you do a 90% fill your ride quality is dismal and if large enough rocks are hit with sufficient force you can actually split a tire open.
/ Rim Guard and punctures #31
If using Rim Guard, can tire be plugged and have it hold? Currently the Ag tires on a machine I bought used are plugged. Maybe a newbie mistake, but I never thought to check, or ask. Anyway, after 2 years of use, still holding.
But, am considering loading tires. Local shop only does calcium with inner tubes. So looking at Rim Guard. Can a tire be safely plugged when filled with Rim Guard?
In short, yes. On My TYM the dealer filled all 4 tires with Rimguard. He would not sell a tractor w/loader without it..Twice I had large nails cause a front-tire leak, and successfully plugged the holes using an el-cheap plug kit. Tires are still leak-free 4 years later.
My Branson has WW fluid in the rears. Dealer added upon purchase.
/ Rim Guard and punctures #33
How about RV anti-freeze? It's Water, Propylene Glycol, Glycerin, and rust inhibitors. It's odorless, non-toxic, non-staining.
I wondered the same thing. I’m not sure but I think it’s more expensive than windshield washer.
2018 Genie GTH-5519 (A64126)
2018 Genie...
2022 EZ-GO ELITE...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
