Reverse 3PH Snowblowing: Creeper or Shuttle?
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #1
Smalljobs
Massachusetts
Jinma 284
I've read most of the threads on snow removal and also the general thread for creeper versus shuttle. Since I'm planning to purchase a 254LE soon, I want to make the best decision but I can't seem to find much first hand user experience on which transmission will best suit my needs for the snowblowing application. Any advice on this will be appreciated.
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #2
I have a 2006 284 with creeper and can tell you that the creeper range in reverse is virtually useless for snow blowing. Further, I can also tell you that the hi range reverse is much too fast for blowing and the low range reverse is a might too slow (but the only practical gear to use). I cannot comment on the shuttle but it seems logical that it would be better. I have blown a lot of snow in that gear:eek:
Regards
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #3
I run a rear blower with a geared tranny.
Hi reverse is much too fast for any snows that need blowing.
Low is fine for the 4-10 inch falls depending on density of the snow.
Usually when snowfalls are in the 6-12 debth I find that I want to make less than full passes in order to keep RPM's up
All that being said I sure wish I had a creeper gear, especially when cutting back snow banks, while slower I could take full passes and get it done with.
Entrance ways filled by the city plow would be a snap with creeper gear.
If not a $$ extra, I'd suggest you take it.(or upgrade to hydrostatic)
/ Reverse 3PH Snowblowing: Creeper or Shuttle? #4
The beauty of a shuttle transmission is that for every forward gear choice, there is a reverse choice. True whether we are talking about a manual shuttle, hydraulic shuttle of whatever name, or a powershift with a reverser. Snowblowing in reverse is all about speed/gearing choices; the more you have, the better the chances you will find a reverse speed that matches your conditions and comfort level.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
2007 Freightliner B2 School Bus (A61573)
2007 Freightliner...
2015 John Deere 8345R (A64119)
2015 John Deere...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
